Thanks: 19 times Was thanked: 4 time(s) in 1 post(s)
I have a list input with about 6 videos.
I want to fade to this input play a video and go back to preview...
So i have set two triggers: On Completion - Fade Preview -> This works great get to the end of a video and then we fade back to where we were. On Transition Out - NextItem - MyList, Current - This works fine until we get to the end of the list and i have no way of knowing when to reset this back to the beginning. - This is going to be an unattended system!
I have tried the loop and that just loops the current item - any other ideas please?
Rank: Guest
Groups: Guests
I was wondering the same thing as well....had a list of videos running and had to go and restart every time the list gets to the end......
@ smudge1977 and Bandit62
Have you tried the "PlayList" feature? I would eliminate the "Triggers" (as they may screw things up when using the "PlayList").
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
I don't think there is a way to do this at this time. vMix is really not designed for unattended access, the triggers are intended as time savers but not necessarily operator replacers!
Martin vMix
Joined: 8/22/2013(UTC) Posts: 92  Location: Rochester, NY Was thanked: 13 time(s) in 9 post(s)
I wondered the same thing. I have a list of ads that I'm going to run. I was wondering what happened when it got to the end of the list.
Is it not easy enough to add a repeat button? Sort of like iTunes or any other audio program that lets you start over once the list is completed?
-Brian
