smudge1977
#1 Posted : Friday, January 27, 2017 6:44:29 AM(UTC)
smudge1977
Was thanked: 4 time(s) in 1 post(s)
I have a list input with about 6 videos.
I want to fade to this input play a video and go back to preview...
So i have set two triggers:
On Completion - Fade Preview -> This works great get to the end of a video and then we fade back to where we were.
On Transition Out - NextItem - MyList, Current - This works fine until we get to the end of the list and i have no way of knowing when to reset this back to the beginning. - This is going to be an unattended system!
I have tried the loop and that just loops the current item - any other ideas please?
Bandit62
#2 Posted : Friday, January 27, 2017 7:45:44 AM(UTC)
Rank: Guest
Groups:
I was wondering the same thing as well....had a list of videos running and had to go and restart every time the list gets to the end......
#3 Posted : Friday, January 27, 2017 11:15:19 AM(UTC)
@ smudge1977 and Bandit62
Have you tried the "PlayList" feature?
I would eliminate the "Triggers" (as they may screw things up when using the "PlayList").
#4 Posted : Sunday, January 29, 2017 6:55:37 AM(UTC)
I don't think there is a way to do this at this time.
vMix is really not designed for unattended access, the triggers are intended as time savers but not necessarily operator replacers!
tesn
#5 Posted : Sunday, January 29, 2017 5:59:13 PM(UTC)
tesn
Was thanked: 13 time(s) in 9 post(s)
I wondered the same thing. I have a list of ads that I'm going to run. I was wondering what happened when it got to the end of the list.
Is it not easy enough to add a repeat button? Sort of like iTunes or any other audio program that lets you start over once the list is completed?
-Brian
Similar Topics
Companion List Input next item (General Discussion)
by Panic 5/22/2021 7:13:38 AM(UTC)
