Panic
#1 Posted : Saturday, May 22, 2021 7:13:38 AM(UTC)
Panic
Is there not a way to select the next item in a “list” input (not a playlist) with a shortcut or anything I can access with companion?
#2 Posted : Saturday, May 22, 2021 3:13:33 PM(UTC)
NextItem
menetekel
#3 Posted : Wednesday, June 23, 2021 11:18:42 PM(UTC)
menetekel
Germany
hey,
any solution so far? i have the same issue.
i try to set a button for selecting next item in a multimedia-list.
in vmix there is the shortcut "NextItem" "PreviousItem" i can assign to an input. works fine.
but i want to create a companion-button.
maybe with a customcommand? just dont know about these yet.
best,
felix
menetekel
#4 Posted : Wednesday, June 23, 2021 11:58:02 PM(UTC)
menetekel
Germany
ok. one step further.
custom command <http://192.168.0.209:8088/api/?function=NextItem&Input=2>
works when i enter in browser.
but dont work when i put on streamdeck-button via companion (Action: vmix: Run custom command)nothing happens. any idea ?
All other actions from companion works fine.
matkeane
#5 Posted : Thursday, June 24, 2021 12:09:54 AM(UTC)
matkeane
Was thanked: 21 time(s) in 21 post(s)
Are the 'Slides - Next Picture/Slide' & 'Slides - Previous Picture/Slide' commands not working for you ? Admittedly, it's not the most intuitive name if you're looking to control a List input, but vMix uses the same command for Slideshows and Lists, so it works for both.
thanks 1 user thanked matkeane for this useful post.
menetekel on 6/24/2021(UTC)
menetekel
#6 Posted : Thursday, June 24, 2021 5:41:17 PM(UTC)
menetekel
Germany
hey,
thank you matkeane. works fine.
i allways thought that the command next slide only works to ppt...
all right. first problem solved.
but why is my custom command not working on a companion-button?
the Action "Run custom command" allows only "short" commands like <fade> or <play> but i cant set values like Input-number
matkeane
#7 Posted : Friday, June 25, 2021 6:13:20 PM(UTC)
matkeane
For a custom command, you have to enter the entire command yourself - there's no field for the Input number or values. So in the command field you can enter something like :
Code:
Restart Input=30
or
Code:
SelectIndex Value=1&Input=34
P.S. Not sure the code blocks are the best way to do this, but adding quotes might get confusing.
