Companion List Input next item
Joined: 5/19/2021(UTC) Posts: 17  Was thanked: 1 time(s) in 1 post(s)
Is there not a way to select the next item in a “list” input (not a playlist) with a shortcut or anything I can access with companion?
Joined: 6/23/2021(UTC) Posts: 5  Location: Jena Thanks: 2 times
hey,
any solution so far? i have the same issue. i try to set a button for selecting next item in a multimedia-list. in vmix there is the shortcut "NextItem" "PreviousItem" i can assign to an input. works fine. but i want to create a companion-button.
maybe with a customcommand? just dont know about these yet.
best, felix
ok. one step further. custom command <http://192.168.0.209:8088/api/?function=NextItem&Input=2> works when i enter in browser. but dont work when i put on streamdeck-button via companion (Action: vmix: Run custom command)nothing happens. any idea ?
All other actions from companion works fine.
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
Are the 'Slides - Next Picture/Slide' & 'Slides - Previous Picture/Slide' commands not working for you ? Admittedly, it's not the most intuitive name if you're looking to control a List input, but vMix uses the same command for Slideshows and Lists, so it works for both.
 1 user thanked matkeane for this useful post.
hey,
thank you matkeane. works fine. i allways thought that the command next slide only works to ppt...
all right. first problem solved.
but why is my custom command not working on a companion-button? the Action "Run custom command" allows only "short" commands like <fade> or <play> but i cant set values like Input-number
For a custom command, you have to enter the entire command yourself - there's no field for the Input number or values. So in the command field you can enter something like : or Code:SelectIndex Value=1&Input=34
P.S. Not sure the code blocks are the best way to do this, but adding quotes might get confusing.
