Need 2 HDMI Camera Inputs to PC
My Church PC (vmix) has / 1 PCIe16x(Video Out Card) / 1 PCIe1x(HDMI Capture Card) / 1 Regular PCI Slot(Sound Card) / and 1 Open Regular PCI Slot. How do we get a second HDMI Input for our vmix PC (Important both cameras capture exact hdmi quality). Thank You
Joined: 10/29/2013(UTC) Posts: 57 Location: Conroe TX
Thanks: 6 times Was thanked: 5 time(s) in 5 post(s)
Consider replacing the one capture card with a double or quad card.
The Magewell Pro Capture Quad Card runs about $900, but would give you 4 inputs....what you need for today and future growing room.
The Magewell Pro Capture Dual Card would give you what you need, but no more at a price of about $580.
If you have an available USB3, you might consider a Magewell USB3 Capture Device at $300.
There are other brands of course, but Magewell has worked for me.
Thanks Ed. These cards appear to need a PCIe 4x slot which we do not have, only a PCIe 1x. The PCIex16 slot is used and we do not have a USB3
Intel(R)Core(TM)2 Duo CPU E7300 @2.66GHz 2.67GHz / 4GB RAM
If I did go with this USB 3.0 Card, How do I connect my HDMI out from my camera to the USB 3.0 Card. Thank YOu
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Quote:If I did go with this USB 3.0 Card, How do I connect my HDMI out from my camera to the USB 3.0 Card. With a HDMI cable. Magewell USB3 Capture Device have a HDMI input converted over USB3 for PC connection. Are you sure you have USB3 on this PC? I didn't check the model but it's quite an old computer I guess. If no USB3, Magewell is not an option and you might consider getting a newer motherboard/CPU imho.
Joined: 5/13/2014(UTC) Posts: 520   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
webmasterpaul wrote:My Church PC (vmix) has / 1 PCIe16x(Video Out Card) / 1 PCIe1x(HDMI Capture Card) / 1 Regular PCI Slot(Sound Card) / and 1 Open Regular PCI Slot. How do we get a second HDMI Input for our vmix PC (Important both cameras capture exact hdmi quality). Thank You I think the bottom line is that you need a different/newer motherboard if you want to capture two or more HDMI inputs in HD quality. Neither a regular PCI slot nor USB2 has sufficient bandwidth for uncompressed full-HD video, although that PCI-USB3 card might be OK for 720p30.
You have been a member since:: 5/11/2016(UTC) Posts: 4 Location: Indonesia
webmasterpaul wrote:My Church PC (vmix) has / 1 PCIe16x(Video Out Card) / 1 PCIe1x(HDMI Capture Card) / 1 Regular PCI Slot(Sound Card) / and 1 Open Regular PCI Slot. How do we get a second HDMI Input for our vmix PC (Important both cameras capture exact hdmi quality). Thank You buy new PCIx capture card w/ 2 HDMI inputs. somethin' like this; http://img.dxcdn.com/productimages/sku_72046_1.jpg
