webmasterpaul
#1 Posted : Thursday, January 19, 2017 10:47:09 PM(UTC)
webmasterpaul
My Church PC (vmix) has / 1 PCIe16x(Video Out Card) / 1 PCIe1x(HDMI Capture Card) / 1 Regular PCI Slot(Sound Card) / and 1 Open Regular PCI Slot. How do we get a second HDMI Input for our vmix PC (Important both cameras capture exact hdmi quality). Thank You
Ed Tech
#2 Posted : Thursday, January 19, 2017 11:13:25 PM(UTC)
Ed Tech
Consider replacing the one capture card with a double or quad card.
The Magewell Pro Capture Quad Card runs about $900, but would give you 4 inputs....what you need for today and future growing room.
The Magewell Pro Capture Dual Card would give you what you need, but no more at a price of about $580.
If you have an available USB3, you might consider a Magewell USB3 Capture Device at $300.
There are other brands of course, but Magewell has worked for me.
webmasterpaul
#3 Posted : Thursday, January 19, 2017 11:32:46 PM(UTC)
webmasterpaul
Thanks Ed. These cards appear to need a PCIe 4x slot which we do not have, only a PCIe 1x. The PCIex16 slot is used and we do not have a USB3
SportsNetUSA.net
#4 Posted : Thursday, January 19, 2017 11:58:01 PM(UTC)
SportsNetUSA.net
This could give you USB 3.0 capacity with a PCI slot, but only has bandwidth up to 1.3 Gbps.
https://www.startech.com/Cards-A...th-SATA-Power~PCIUSB3S22
What CPU does your church computer have?
webmasterpaul
#5 Posted : Friday, January 20, 2017 3:16:28 AM(UTC)
webmasterpaul
Intel(R)Core(TM)2 Duo CPU E7300 @2.66GHz 2.67GHz / 4GB RAM
If I did go with this USB 3.0 Card, How do I connect my HDMI out from my camera to the USB 3.0 Card. Thank YOu
#6 Posted : Friday, January 20, 2017 4:30:08 AM(UTC)
With a HDMI cable. Magewell USB3 Capture Device have a HDMI input converted over USB3 for PC connection.
Are you sure you have USB3 on this PC? I didn't check the model but it's quite an old computer I guess. If no USB3, Magewell is not an option and you might consider getting a newer motherboard/CPU imho.
zenvideo
#7 Posted : Friday, January 20, 2017 4:38:01 AM(UTC)
zenvideo
I think the bottom line is that you need a different/newer motherboard if you want to capture two or more HDMI inputs in HD quality. Neither a regular PCI slot nor USB2 has sufficient bandwidth for uncompressed full-HD video, although that PCI-USB3 card might be OK for 720p30.
marosa
#8 Posted : Tuesday, January 24, 2017 8:35:15 AM(UTC)
marosa
buy new PCIx capture card w/ 2 HDMI inputs.
somethin' like this;
http://img.dxcdn.com/productimages/sku_72046_1.jpg
Guest (4)
