3 windows images or cameras
Hello Martin. I want a help. How can with vmix, three horizontal images ;or three cameras. As the picture that I attach. Thank you Apostolos apell attached the following image(s):  3 windows.jpg (14kb) downloaded 3 time(s).You cannot view/download attachments. Try to login or register.
Thanks for your support. I want if there a Virtual Set for 3 images or cameras Thank you
@ apell
There is no existing template to match your image above, but you can easily save a 'preset' of your own.
IceStream wrote:@ apell
Ice Hi Ice, Sorry, but how to do it? Apostolos
As indicated in the doc for multiview "Once the positions have been configured, the Add button on the right hand side can be used to create a template."
It means you configure your multiview with your 3 sources (you need to use the position options) and when you're happy with it, you click on ADD in the multiview tab to memorize your setup
