apell
#1 Posted : Monday, January 23, 2017 7:53:07 PM(UTC)
apell
Hello Martin. I want a help.
How can with vmix, three horizontal images ;or three cameras. As the picture that I attach.
Thank you
Apostolos
apell attached the following image(s):
3 windows.jpg (14kb) downloaded 3 time(s).
#2 Posted : Monday, January 23, 2017 8:47:56 PM(UTC)
Hi!
check this :
http://www.vmix.com/help...utSettingsMultiView.html
This is what you're looking for.
Guillaume
apell
#3 Posted : Tuesday, January 24, 2017 5:30:22 AM(UTC)
apell
Thanks for your support.
I want if there a Virtual Set for 3 images or cameras
Thank you
#4 Posted : Tuesday, January 24, 2017 12:09:23 PM(UTC)
@ apell
There is no existing template to match your image above, but you can easily save a 'preset' of your own.
apell
#5 Posted : Tuesday, January 24, 2017 1:29:30 PM(UTC)
apell
IceStream wrote:
@ apell
Hi Ice,
Sorry, but how to do it?
Apostolos
#6 Posted : Tuesday, January 24, 2017 1:42:28 PM(UTC)
As indicated in the doc for multiview "Once the positions have been configured, the Add button on the right hand side can be used to create a template."
It means you configure your multiview with your 3 sources (you need to use the position options) and when you're happy with it, you click on ADD in the multiview tab to memorize your setup
Similar Topics
3 windows images or cameras (General Discussion)
by apell 1/23/2017 8:02:24 PM(UTC)
