Hi Forum!
I just tested the Logitech C920 with vMix and while it works, i can only get like 5 FPS with any resolution higher than 640x480.
Now my understanding is, that vMix doesn´t supports the C920´s built-in H.264 encoding. Is there any chance to get this in an next update or something? That would be *so much* appreciated.
Or am i doing something wrong and this is already possible somehow?
Thanks and all the best! :-)
EDIT: Oh, i should have installed the Logitech Driver first. Now it appears with almost 30fps per second. simply amazing so far... but still not sure if this is H264 then or not.
