#1 Posted : Wednesday, December 28, 2016 5:07:24 PM(UTC)
How does one check on the master volume ie hear the change using the master volume slider (V18 windows 10) ?
Cpilcher
#2 Posted : Wednesday, December 28, 2016 5:21:24 PM(UTC)
Cpilcher
Personally, I use an external recorder (Atamos Ninja) to record a High Res backup recording and I use that to monitor the final output of Audio and Video.
Chuck
ovinas
#3 Posted : Wednesday, December 28, 2016 5:53:50 PM(UTC)
ovinas
Set an audio output for the master audio bus in the settings and connect headphones or speakers to it?
http://www.vmix.com/help...ex.htm?AudioOutputs.html
#4 Posted : Wednesday, December 28, 2016 6:22:35 PM(UTC)
get response on the individual input sliders not the master audio slider
so even if that slider was all the way down i have no audible verification on that one
zenvideo
#5 Posted : Wednesday, December 28, 2016 7:49:15 PM(UTC)
zenvideo
Start by checking the vMix Audio Output settings to make sure that both the Master Output and Headphones are not going to the same device (eg. Default Windows Playback Device), or else turning down the master fader may still result in the same audio going to the output, via the Headphone level control. In other words, (a) don't send both logical outputs to the same physical audio device, and (b) make sure the device that's taking the Master audio is the one that you're actually listening to - and then is should work :)
sinc747 on 12/29/2016(UTC)
#6 Posted : Wednesday, December 28, 2016 8:10:27 PM(UTC)
@Zenvideo
thank you !
