How does one listen to the master volume ?
How does one check on the master volume ie hear the change using the master volume slider (V18 windows 10) ?
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
Personally, I use an external recorder (Atamos Ninja) to record a High Res backup recording and I use that to monitor the final output of Audio and Video.
Chuck
get response on the individual input sliders not the master audio slider so even if that slider was all the way down i have no audible verification on that one
Start by checking the vMix Audio Output settings to make sure that both the Master Output and Headphones are not going to the same device (eg. Default Windows Playback Device), or else turning down the master fader may still result in the same audio going to the output, via the Headphone level control. In other words, (a) don't send both logical outputs to the same physical audio device, and (b) make sure the device that's taking the Master audio is the one that you're actually listening to - and then is should work :)
 1 user thanked zenvideo for this useful post.
