Recorder stops after 50 minutes
Joined: 8/2/2013(UTC) Posts: 1,098   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
Have two clients who have had this happen recently. The recording spontaneously stopped after about 50 minutes.
Has anyone experienced anything similar? Thanks.
- Tom
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
I record MP4 50mb for hours at a time without any problem. Did they get the PC from you?
Chuck
The PC's are not ones I built. Built by a third party.
- Tom
Do you have more info? Used codec, bitrate, etc...
Good question. I should know better than to omit that info.
Recorder Specs: MP4 resolution: 1920x1080 frame rate: 29.97p bit rate: 8Mbps profile: H264baseline Hardware Encoder Not checked GTX960 card present.
- Tom
Here's another question or two - 1) How big are the files when the recording stops (if you can still see them on the disk)? 2) What file system has been used to format the disks onto which the recordings are being made?
I believe there's a 4GB file size limit on FAT32 partitions. I wouldn't have thought you'd be hitting that with the recording spec stated, but it's worth checking just in case.
Joined: 1/13/2010(UTC) Posts: 5,316  Location: Gold Coast, Australia Was thanked: 4718 time(s) in 1616 post(s)
The important thing to check is what message appears when the recording stops. There will always be some kind of popup error message when it stops and that will be the key to determining what is happening.
Otherwise the only way for the recording to stop without a message is if a shortcut key has been assigned to StopRecording and it has been pressed accidentally.
Martin vMix
Will check those items. Thanks, Martin & Martin!
- Tom
