sinc747
#1 Posted : Friday, December 16, 2016 5:22:43 PM(UTC)
sinc747
Was thanked: 207 time(s) in 173 post(s)
Have two clients who have had this happen recently. The recording spontaneously stopped after about 50 minutes.
Has anyone experienced anything similar? Thanks.
- Tom
Cpilcher
#2 Posted : Saturday, December 17, 2016 11:56:18 AM(UTC)
Cpilcher
I record MP4 50mb for hours at a time without any problem. Did they get the PC from you?
Chuck
sinc747
#3 Posted : Saturday, December 17, 2016 6:56:22 PM(UTC)
sinc747
The PC's are not ones I built. Built by a third party.
- Tom
Mathijs
#4 Posted : Saturday, December 17, 2016 8:21:38 PM(UTC)
Mathijs
Do you have more info? Used codec, bitrate, etc...
sinc747
#5 Posted : Saturday, December 17, 2016 9:10:54 PM(UTC)
sinc747
Good question. I should know better than to omit that info.
Recorder Specs:
MP4
resolution: 1920x1080
frame rate: 29.97p
bit rate: 8Mbps
profile: H264baseline
Hardware Encoder Not checked
GTX960 card present.
- Tom
zenvideo
#6 Posted : Sunday, December 18, 2016 5:46:23 AM(UTC)
zenvideo
Here's another question or two -
1) How big are the files when the recording stops (if you can still see them on the disk)?
2) What file system has been used to format the disks onto which the recordings are being made?
I believe there's a 4GB file size limit on FAT32 partitions. I wouldn't have thought you'd be hitting that with the recording spec stated, but it's worth checking just in case.
#7 Posted : Sunday, December 18, 2016 2:21:55 PM(UTC)
The important thing to check is what message appears when the recording stops.
There will always be some kind of popup error message when it stops and that will be the key to determining what is happening.
Otherwise the only way for the recording to stop without a message is if a shortcut key has been assigned to StopRecording
and it has been pressed accidentally.
sinc747
#8 Posted : Tuesday, December 20, 2016 6:50:26 PM(UTC)
sinc747
Will check those items. Thanks, Martin & Martin!
- Tom
