Hi there.
I'm experiencing an issue with video inputs using vMix8 on Windows XP. Some videos work fine, some don't: i just hear audio and no image. Can't figure out any difference between them. The same happens trying to load .avi, .mpeg, .mov videos.
Any suggestion? Thanks in advance. Cya
Rank: Guest
Groups: Guests
First of all, thanks for your answer.
When I first noticed the issue I thought the same, that it was a codec problem. But I already had a k-lite codec pack installed, and with vMix 2012 everything just worked fine. The problem began after I upgraded to vMix 8.
Anyway, I also tried to install the mega codec pack as you suggested but nothing changes.
What could I try now? Thanks.
Regards.
What graphics card do you have? vMix 8 includes some new graphics features that require a recent graphics card.
Martin vMix
Quite an old one actually, it's an ATI Radeon about 6 years old.
It could be that the problem? Even in reproducing simple .avi or .mpg file?
Thanks for your help.
