araton
#1 Posted : Wednesday, November 28, 2012 8:23:04 PM(UTC)
araton
Hi there.
I'm experiencing an issue with video inputs using vMix8 on Windows XP. Some videos work fine, some don't: i just hear audio and no image. Can't figure out any difference between them. The same happens trying to load .avi, .mpeg, .mov videos.
Any suggestion?
Thanks in advance.
Cya
melody
#2 Posted : Wednesday, November 28, 2012 9:24:40 PM(UTC)
Rank: Guest
Groups: Guests
hi araton,
try to install k-lite mega codec pack... your problem must be some video codecs that are not installed, click below to download latest version:
http://www.free-codecs.c...lite_mega_codec_pack.htm
regards,
melody
www.espiritosanto.cc
araton
#3 Posted : Thursday, November 29, 2012 5:29:04 AM(UTC)
araton
First of all, thanks for your answer.
When I first noticed the issue I thought the same, that it was a codec problem. But I already had a k-lite codec pack installed, and with vMix 2012 everything just worked fine. The problem began after I upgraded to vMix 8.
Anyway, I also tried to install the mega codec pack as you suggested but nothing changes.
What could I try now? Thanks.
Regards.
#4 Posted : Friday, November 30, 2012 1:42:02 AM(UTC)
What graphics card do you have?
vMix 8 includes some new graphics features that require a recent graphics card.
araton
#5 Posted : Friday, November 30, 2012 4:07:01 PM(UTC)
araton
Quite an old one actually, it's an ATI Radeon about 6 years old.
It could be that the problem? Even in reproducing simple .avi or .mpg file?
Thanks for your help.
