op music
#1 Posted : Sunday, December 4, 2016 11:59:12 AM(UTC)
op music
Hi I wanted to know if this card Blackmagic DeckLink Studio 2 works with Vmix if I understand you can capture and play simultaneously? Thank you
BETech
#2 Posted : Sunday, December 4, 2016 1:53:56 PM(UTC)
BETech
The Decklink Studio 2 is mono-directional, either capture or playback. Most likely due the fact that the card is an A-D and D-A converter, with analogue, AES/EBU & embedded SDI sound options, plus composite, component YRB/YC and SDI video. It’s very similar to the Decklink Ultra-Studio Pro USB3 device in operation and function. A great playback card, as it provides all the possible solutions for analogue/digital audio and composite/component/SD-SDI/HD-SDI video environments. Plus HDMI capture and playback. A real all-rounder.
thanks 1 user thanked BETech for this useful post.
op music on 12/4/2016(UTC)
#3 Posted : Sunday, December 4, 2016 4:49:05 PM(UTC)
@ op music
Perhaps you are confusing it with the Decklink Duo or Duo 2...
Which are capable of simultaneous IN and Out feeds.
csepi74
#4 Posted : Monday, December 5, 2016 2:07:20 PM(UTC)
csepi74
Choose the Decklink SDI 4K...it can capture and play simultaneously.
thanks 1 user thanked csepi74 for this useful post.
op music on 12/6/2016(UTC)
Similar Topics
Blackmagic Decklink Studio 2 (Hardware Compatibility)
by FCC 2/3/2013 11:01:46 AM(UTC)
