Hi, I wanted to know if it is possible 2 video cameras in the virtual set in chroma key, thanks
Joined: 3/30/2014(UTC) Posts: 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
Why not import the same virtual set twice and then add a camera to each virtual set.
hi, so I do, I thought there was another way, even for the prospects, thanks
Joined: 3/7/2012(UTC) Posts: 2,688  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ op music
Not sure I understand the question, can you elaborate? (my understanding is that a "Virtual Set" can have up to 5 Overlay Inputs as per "Multiview", so depending how many are used and/or locked on the set will determine the possibilities)
Hello Ice, the question was put multiple cameras in a single virtual set without putting other virtual Set Thank you
Joined: 12/27/2012(UTC) Posts: 5,516  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
What I think Ice was saying is that a VS can have layers similar to a multiview . Each layer can be any input you like , so yes also multiple camera inputs in VS. Just did try it each camera input with is own chroma key. layout is depending on VS design compared to a regular multiview
Guy
