op music
#1 Posted : Tuesday, November 15, 2016 6:46:13 AM(UTC)
op music
Hi, I wanted to know if it is possible 2 video cameras in the virtual set in chroma key, thanks
Len56
#2 Posted : Wednesday, November 16, 2016 10:34:35 AM(UTC)
Len56
Why not import the same virtual set twice and then add a camera to each virtual set.
op music
#3 Posted : Wednesday, November 16, 2016 11:04:44 AM(UTC)
op music
hi, so I do, I thought there was another way, even for the prospects, thanks
#4 Posted : Wednesday, November 16, 2016 7:32:24 PM(UTC)
@ op music
Not sure I understand the question, can you elaborate?
(my understanding is that a "Virtual Set" can have up to 5 Overlay Inputs as per "Multiview", so depending how many are used and/or locked on the set will determine the possibilities)
op music
#5 Posted : Thursday, November 17, 2016 6:16:48 AM(UTC)
op music
Hello Ice, the question was put multiple cameras in a single virtual set without putting other virtual Set Thank you
#6 Posted : Thursday, November 17, 2016 6:53:11 AM(UTC)
What I think Ice was saying is that a VS can have layers similar to a multiview .
Each layer can be any input you like , so yes also multiple camera inputs in VS.
Just did try it each camera input with is own chroma key. layout is depending on VS design compared to a regular multiview
Guy
op music on 11/17/2016(UTC)
