#1 Posted : Friday, August 17, 2012 3:01:22 AM(UTC)
Was thanked: 4708 time(s) in 1613 post(s)
The vMix Tally Light Set is now available for purchase!
The price is $350 AUD + $20 AUD International Postage
Includes
1x USB Unit with 4 Tally Light ports
4x Tally Lights with Green and Red LED
4x 5M cables to link Tally Lights with USB Unit
These are standard 3.5mm Stereo Male-Male cables so you can build your own cables to cover longer distances.
1x USB Cable
Ordering Instructions
1. Order Here
2. You will receive confirmation from us within 1 business day.
3. Items will be shipped within 5 business days and will arrive within 14-21 days depending on location.
Installation Instructions
An automatic driver installer for Vista / Windows 7 is available below:
Download vMix Tally Lights Driver
Warranty
Each set includes a 1 year warranty.
donnyyeo
#2 Posted : Friday, August 17, 2012 11:09:55 AM(UTC)
donnyyeo
How to mount the tally light unit to the video camera?
Is there a hot shoe or tripod mount at the bottom?
The cable can be how long?
Is there a need for batteries at the tally light unit?
#3 Posted : Saturday, August 18, 2012 12:57:13 AM(UTC)
Each tally light has 2 holes on each side which can be used create a custom attachment to suit the camera.
You could also drill a hole into the lid of each tally light as it has indentations designed to assist drilling.
Cables up to 40m or so in length should work fine. You could build stereo 3.5mm to cat5 cables to extend further.
The tally lights do not require any batteries or an external power source.
guztavo
#4 Posted : Monday, October 15, 2012 12:55:20 PM(UTC)
guztavo
Hi Martin!
It's possible to buy just the board ("OEM")?
I want to go on with my hardware switcher and vMix handling lights will be excellent for me.
Thanks!
Regards.
#5 Posted : Tuesday, October 16, 2012 12:28:57 AM(UTC)
The board is the freely available Arduino Uno
See: http://www.vmix.com.au/help2012v5/TallyLights.html
johnparrack
#6 Posted : Friday, November 2, 2012 12:28:51 PM(UTC)
johnparrack
Hi Martin, Is there an output option for just connecting to standard Camera tally inputs....for instance via Sony ccu's and is it a contact closure tally? or if i converted the 3.5 to Xlr?
Obviously most Sony heads (both older sd heads like the D50, and HD heads like the 1000) take the tally via Xlr connector on the CCU.....just thinking down the line for my own uses really.
mmorlan62
#7 Posted : Tuesday, February 5, 2013 4:24:32 PM(UTC)
mmorlan62
Was thanked: 7 time(s) in 5 post(s)
Being a tinker/maker conversant in Aruino, I truly appreciate vMix support of tally lights through that embedded platform. Looks like I'll be building a small tally light setup myself.
Thanks!
Michael
mmorlan62
#8 Posted : Saturday, June 15, 2013 3:24:08 PM(UTC)
mmorlan62
Following up, do you have an Arduino code segment so I may determine what messages you send to Arduino?
I'm actually going to use your tally light system to turn the vMix audio output to a talent earpiece on and off depending on which input I have queued.
Thanks,
Michael
#9 Posted : Sunday, June 16, 2013 7:56:40 AM(UTC)
Hi Michael,
vMix simply sends a digital on/off to the relevant pins.
You can see the pin mappings in vMix Settings -> Tally Lights
h2video.nl
#10 Posted : Sunday, September 8, 2013 12:46:27 AM(UTC)
h2video.nl
is thera way to get tally light info and / or a settings overview of inputs etc via wifi on an ipad. just the way the remote works.
this way tally info could be provided wireless to a cameraoperator and this would solve a big cabling problem.
alteratively specific info could be sent over something like whats app. something like cam on cam off so at least the cameraman knows he is live or not. any ideas?
stefan
#11 Posted : Sunday, September 8, 2013 1:24:39 AM(UTC)
I thought about the idea of having a page available like the following:
http://localhost:8088/tally1
The page would just show a solid colour (green, orange or red) and change depending on the status of the tally lights.
Then it could be used with any mobile phone with wifi access.
Is this something people would find useful?
h2video.nl
#12 Posted : Sunday, September 15, 2013 2:58:48 AM(UTC)
h2video.nl
perfect!
stefan
Streamevent
#13 Posted : Sunday, September 15, 2013 3:29:40 AM(UTC)
Streamevent
great!
If it runs togheter with the Teamspeak client the audio
communication with the cameramen would be also solved.
Regards
Damn2Good4U
#14 Posted : Sunday, September 15, 2013 10:21:29 AM(UTC)
Damn2Good4U
Perfecto
#15 Posted : Thursday, September 26, 2013 5:56:52 AM(UTC)
The vMix Tally Light Set is being superseded by a new WiFi / phone based system in vMix 11!
This means you will be able to instantly turn any WiFi mobile phone into a Tally Light and mount it above or next to your cameras.
Cheap WiFi enabled phones are available on eBay for $50 US making this a very cost effective solution (no SIM required).
We still have plenty of the existing Tally Light sets for sale for those that prefer wired solution and they will continue
to be supported by all future versions of vMix.
#16 Posted : Thursday, September 26, 2013 9:15:40 AM(UTC)
This sounds very interesting, will any WiFi enabled device such as the iPod touch work as well?
Guest (7)
