vMix Tally Light Set - Now Available
Joined: 1/13/2010(UTC) Posts: 5,320  Location: Gold Coast, Australia Was thanked: 4720 time(s) in 1617 post(s)
The vMix Tally Light Set is now available for purchase!  The price is $350 AUD + $20 AUD International Postage Includes1x USB Unit with 4 Tally Light ports 4x Tally Lights with Green and Red LED 4x 5M cables to link Tally Lights with USB Unit These are standard 3.5mm Stereo Male-Male cables so you can build your own cables to cover longer distances. 1x USB Cable Ordering Instructions1. Order Here2. You will receive confirmation from us within 1 business day. 3. Items will be shipped within 5 business days and will arrive within 14-21 days depending on location. Installation InstructionsAn automatic driver installer for Vista / Windows 7 is available below: Download vMix Tally Lights DriverWarrantyEach set includes a 1 year warranty.
Rank:: Member
How to mount the tally light unit to the video camera?
Is there a hot shoe or tripod mount at the bottom?
The cable can be how long?
Is there a need for batteries at the tally light unit?
Each tally light has 2 holes on each side which can be used create a custom attachment to suit the camera. You could also drill a hole into the lid of each tally light as it has indentations designed to assist drilling.
Cables up to 40m or so in length should work fine. You could build stereo 3.5mm to cat5 cables to extend further.
The tally lights do not require any batteries or an external power source.
Martin vMix
Joined: 8/21/2012(UTC) Posts: 194  Location: Cordoba - Argentina Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Hi Martin!
It's possible to buy just the board ("OEM")? I want to go on with my hardware switcher and vMix handling lights will be excellent for me.
Thanks! Regards.
Joined: 10/23/2012(UTC) Posts: 8 Location: Bournemouth
Hi Martin, Is there an output option for just connecting to standard Camera tally inputs....for instance via Sony ccu's and is it a contact closure tally? or if i converted the 3.5 to Xlr?
Obviously most Sony heads (both older sd heads like the D50, and HD heads like the 1000) take the tally via Xlr connector on the CCU.....just thinking down the line for my own uses really.
Joined: 1/23/2013(UTC) Posts: 65  Thanks: 3 times Was thanked: 7 time(s) in 5 post(s)
Being a tinker/maker conversant in Aruino, I truly appreciate vMix support of tally lights through that embedded platform. Looks like I'll be building a small tally light setup myself.
Thanks!
Michael
Following up, do you have an Arduino code segment so I may determine what messages you send to Arduino?
I'm actually going to use your tally light system to turn the vMix audio output to a talent earpiece on and off depending on which input I have queued.
Thanks,
Michael
Hi Michael,
vMix simply sends a digital on/off to the relevant pins. You can see the pin mappings in vMix Settings -> Tally Lights
Martin vMix
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
is thera way to get tally light info and / or a settings overview of inputs etc via wifi on an ipad. just the way the remote works.
this way tally info could be provided wireless to a cameraoperator and this would solve a big cabling problem.
alteratively specific info could be sent over something like whats app. something like cam on cam off so at least the cameraman knows he is live or not. any ideas? stefan
I thought about the idea of having a page available like the following:
http://localhost:8088/tally1
The page would just show a solid colour (green, orange or red) and change depending on the status of the tally lights. Then it could be used with any mobile phone with wifi access.
Is this something people would find useful?
Martin vMix
Joined: 8/18/2013(UTC) Posts: 44 Location: Switzerland
Thanks: 1 times Was thanked: 5 time(s) in 4 post(s)
great! If it runs togheter with the Teamspeak client the audio communication with the cameramen would be also solved.
Regards Martin
admin wrote:I thought about the idea of having a page available like the following:
Martin vMix
Perfecto
The vMix Tally Light Set is being superseded by a new WiFi / phone based system in vMix 11!
This means you will be able to instantly turn any WiFi mobile phone into a Tally Light and mount it above or next to your cameras. Cheap WiFi enabled phones are available on eBay for $50 US making this a very cost effective solution (no SIM required).
We still have plenty of the existing Tally Light sets for sale for those that prefer wired solution and they will continue to be supported by all future versions of vMix.
Martin vMix
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
This sounds very interesting, will any WiFi enabled device such as the iPod touch work as well?
