Steadirob
#1 Posted : Saturday, October 13, 2012 12:37:16 AM(UTC)
Steadirob
Last week, when using V6, I was able to just drag and drop video and image files from anotherWindows Explorer folder into vMix and they would open and be available immediately.
I upgraded to V8.0.8 and cannot do that anymore, unfortunately and hope this can be repaired/activated again.
Rob
#2 Posted : Saturday, October 13, 2012 12:58:41 AM(UTC)
Hi Rob,
It still works in 8 (just tested then)
Try making sure you are dragging into a blank area in the input row instead of on top of another input.
Failing that let me know what file format you are trying to drag, I have tried AVI, WMV, PNG and JPEG just before.
Steadirob
#3 Posted : Saturday, October 13, 2012 1:50:38 AM(UTC)
Steadirob
Hi Martin, it does not work here and now I suspect I have to re-install it again, but properly.
When I installed V8, I choose to do that in the Accessories folder, so I would be able to go back to V6 if needed.
When I now start up V8, I get this W7 action screen asking me if it is OK to change the settings on the computer, something that is not happening with V6.
So I think that I have to uninstall everything and then install V8 as ususal.
what do you suggest?
Rob
#4 Posted : Saturday, October 13, 2012 2:25:35 AM(UTC)
Hi Rob,
Yes, the latest version will need to be installed over the top of the older folder in order to work correctly.
Steadirob
#5 Posted : Saturday, October 13, 2012 2:55:52 AM(UTC)
Steadirob
Thanks, Martin.
I just un-installed and re-installed and the V8 version works now as expected.
I was worried because of the presets that i saved and so on but it all comes back as it was this morning! Perfect.
Thanks for the quick reply.
Rob
