johngoforth
#1 Posted : Tuesday, June 14, 2016 4:46:44 PM(UTC)
johngoforth
Hi guys, I have HXRMC2500 camcoder, i need to send sdi output over fiber, i was looking for cheap and robust(not "alibaba com" level) fiber extender, so i found this sdi over fiber extender for $350, but i want to make sure - are they compatible with Sony HXRMC2500? Thank you :)
desmar
#2 Posted : Tuesday, June 14, 2016 7:31:27 PM(UTC)
desmar
Canada
Noticed your camera specs doesn't have an SDI port.. but has a HDMI port..
So to answer your question, NO it will not work...
Camplex CMX-HDMIF HDMI to Fiber Optic Converter / Extender
http://www.markertek.com/product/cmx-hdmif/camplex-cmx-hdmif-hdmi-to-fiber-optic-converter-extender
or you can use the Blackmagic Micro Converters $85 each for (2x $85) $170
and depending on resolution you can run cable from 393ft to 2791ft... with
Belden cable.
https://www.blackmagicdesign.com/ca/products/microconverters
Cable lengths (FYI Reference)
https://www.belden.com/resourcecenter/tools/upload/TB65_p28.pdf
http://www.belden.com/blog/broadcastav/The-Key-to-Video-Cable-Performance.cfm
thanks 1 user thanked desmar for this useful post.
SportsNetUSA.net on 6/15/2016(UTC)
#3 Posted : Tuesday, June 14, 2016 7:35:13 PM(UTC)
@ johngoforth
I'm not so sure that camera has SDI out...
"1 x HDMI
1 x Composite on BNC female
1 x Analog Audio on 2 x RCA female"
according to B&H.
So you will likely need to convert from HDMI with something like this:
Please note, I have no experience or expertise with this, it's only what I've gleaned.
SportsNetUSA.net
#4 Posted : Wednesday, June 15, 2016 2:25:30 AM(UTC)
SportsNetUSA.net
@desmar
Thanks for the Belden PDF on cable run lengths. Read that blog previously, but the chart is very small and bad res.
@johngoforth
Before you dive into SDI or HDMI over fiber check out how much the fiber cable costs. The Camplex Tactical fiber reels cost more that the Camplex CMX-HDMIF HDMI to Fiber Optic Converter/Extender kit.
desmar
#5 Posted : Wednesday, June 15, 2016 8:26:44 AM(UTC)
desmar
Canada
SportsNetUSA.net wrote:
@desmar
@johngoforth
You can zoom in with acrobat reader, PDF is clear to read...
I have attached a zoom png for you
desmar attached the following image(s):
