Joined: 6/14/2016(UTC) Posts: 1 Location: Los-Angeles CA US
Hi guys, I have HXRMC2500 camcoder, i need to send sdi output over fiber, i was looking for cheap and robust(not "alibaba com" level) fiber extender, so i found this sdi over fiber extender for $350, but i want to make sure - are they compatible with Sony HXRMC2500? Thank you :)
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
 1 user thanked desmar for this useful post.
@ johngoforth I'm not so sure that camera has SDI out... "1 x HDMI 1 x Composite on BNC female 1 x Analog Audio on 2 x RCA female" according to B&H. So you will likely need to convert from HDMI with something like this: Please note, I have no experience or expertise with this, it's only what I've gleaned. Ice
@desmar
Thanks for the Belden PDF on cable run lengths. Read that blog previously, but the chart is very small and bad res.
@johngoforth
Before you dive into SDI or HDMI over fiber check out how much the fiber cable costs. The Camplex Tactical fiber reels cost more that the Camplex CMX-HDMIF HDMI to Fiber Optic Converter/Extender kit.
SportsNetUSA.net wrote:@desmar
@johngoforth
Before you dive into SDI or HDMI over fiber check out how much the fiber cable costs. The Camplex Tactical fiber reels cost more that the Camplex CMX-HDMIF HDMI to Fiber Optic Converter/Extender kit. You can zoom in with acrobat reader, PDF is clear to read... I have attached a zoom png for you desmar attached the following image(s):  Capture.PNG (609kb) downloaded 10 time(s).You cannot view/download attachments. Try to login or register.
