Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
kane wrote:The AirSend Updater scans your system looking for the older 'AirSend' DLL libraries and updates them with new ones that support the NDI protocol. If you uninstall the AirSend Updater it will put the original AirSend DLL files back. Kane Peterson NewTek Thanks Kane! Which is/are those dll's? If it's Processing.AirSend.x86.dll it is clearly not in my Casparcg package (the downloads of Server and Client folders). Also, does the AirSend Updater report if any dll's are found? It does not on my PCs, just terminates without any kind of confirmation of success or not.
 1 user thanked stevespaw for this useful post.
Joined: 11/7/2013(UTC) Posts: 66 Location: Netherlands
Thanks: 21 times Was thanked: 9 time(s) in 8 post(s)
Stevespaw,
I installed the client you gave us the link of. It was a bit overwhelming and somewhat chaotic layout, but I Will Look into it tomorrow.
Thank you! Iason
You have been a member since:: 3/24/2016(UTC) Posts: 331 Location: Chicago, IL
richardgatarski wrote:kane wrote:The AirSend Updater scans your system looking for the older 'AirSend' DLL libraries and updates them with new ones that support the NDI protocol. If you uninstall the AirSend Updater it will put the original AirSend DLL files back. Kane Peterson NewTek Thanks Kane! Which is/are those dll's? If it's Processing.AirSend.x86.dll it is clearly not in my Casparcg package (the downloads of Server and Client folders). Also, does the AirSend Updater report if any dll's are found? It does not on my PCs, just terminates without any kind of confirmation of success or not. The 'NewTek Video Send' installer puts it files in 'C:\Windows\system32' on 32-bit systems or 'C:\Windows\SysWOW64' folder on 64-bit systems. After you run the AirSend Updater you will find the new Processing.AirSend.x86.dll in the same location and the previous file with 'OLD' added to its name. Kane Peterson NewTek
stevespaw wrote:◦For NewTek TriCaster iVGA output you need to install the NewTek driver (optional) Steve, that little line revealed the secret sauce. Unfortunately it was not in TVlason's otherwise excellent Youtube guide. It turns out the name of the NewTek driver's installation kit is "NewTek Network Video Send.exe", and what it install is the AirSend stuff I did not have. In other words, I was fooled by a little bit of name confusion. Of course I then had to run the "NewTek NDI AirSend Updater.exe" which does what Kane said above (although without the updater reporting if it did anything or not). So, in other words I got Casparcg working. Now I will look into why NewBlueFX's Titler Pro Live 2 does not show up as an NDI source for me, but that's another topic. Thank you all for helping out!
Richard, it looks like you have to have the Titler Pro Live 2 Ultimate edition to get the NDI output. I have downloaded both the standard version and the Advanced and both do not include NDI.
ask wrote:Richard, it looks like you have to have the Titler Pro Live 2 Ultimate edition to get the NDI output. I have downloaded both the standard version and the Advanced and both do not include NDI. Well, nahumf reported earlier that it worked not using the Ultimate (which is not released yet). I asked, nahumf for details, still no answer...
Read here....https://www.newbluefx.com/support/help-files/titler-pro-live-2-help/standalone-specific-options
It works for me aswell in the trial mode. Went to TitlerLive Standalone.exe>Device> NDI and worked
TVIason wrote:It works for me aswell in the trial mode. Went to TitlerLive Standalone.exe>Device> NDI and worked What do you mean by "device> NDI"? Is there a setting somewhere for choosing output device?
Yes there is, it's under settings
Strange, I don't have that option in the menu... richardgatarski attached the following image(s):  NewBlueFX_Titler-pro-version-info.PNG (50kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register.
Hmm, because I didn't now how the program could be started, I went to my Program Files folder and started the program from there. (C:\Program Files\NewBlueFX\TitlerLive\TitlerLiveStandalone
Could you try that for me?
Doesn't help. I'll just ask NewBlueFx's support. I'll be back when I know more. Thanks.
