2 Pages<12
stevespaw
#21 Posted : Thursday, March 31, 2016 2:05:47 PM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
I have a new link for CasparCG "Caspar Media Playback" (edit-3-31)
This is an awesome client for trying out what CasperCG can do. Some pieces don't work quite right, But for those that want to get started it is very cool. It will give a glimpse of the real power of the CasperCG engine.
Requirements to run this client
1. DotNet 4.5 or higher https://www.microsoft.com/en-in/download/details.aspx?id=42642
2. Flash player activex https://www.microsoft.com/en-in/download/details.aspx?id=42642
3. VLC 32bit version You must use this version.
4. After you install and run it. Select the "Copy Example Templates" and the "Copy Example Media" buttons.
5. Start to explore.
Caspar Media Playback forum
Steve
richardgatarski
#22 Posted : Thursday, March 31, 2016 3:31:44 PM(UTC)
richardgatarski
kane wrote:
The AirSend Updater scans your system looking for the older 'AirSend' DLL libraries and updates them with new ones that support the NDI protocol. If you uninstall the AirSend Updater it will put the original AirSend DLL files back.
Kane Peterson
NewTek
Thanks Kane!
Which is/are those dll's? If it's Processing.AirSend.x86.dll it is clearly not in my Casparcg package (the downloads of Server and Client folders).
Also, does the AirSend Updater report if any dll's are found? It does not on my PCs, just terminates without any kind of confirmation of success or not.
stevespaw
#23 Posted : Thursday, March 31, 2016 4:37:59 PM(UTC)
stevespaw
CasparCG Server 2.0.7
Stable and production-ready (Updated: 2014-12-11, 143 MB)
Windows 7 32-bit/64-bit
The CasparCG Server software is used to play out and record video, audio and graphics.
Additional downloads:
◦Microsoft .NET Framework 4.0 or later (required)
◦Microsoft Visual C++ 2010 Redistributable Package (required)
◦For Flash template playback you need to install Flash Player 11.8.800.94 (optional)
◦For NewTek TriCaster iVGA output you need to install the NewTek driver (optional)
CasparCG Server frontend
CasparCG Client 2.0.8
Windows XP or later / Mac OS X 10.5 or later / Ubuntu 14.04 LTS 64-bit. (Updated: 2015-10-03, 26–53 MB)
The CasparCG Client software is used to control the playback/recording with one or several CasparCG Servers.
Install the AirSend (Newtek Driver) from above first, then run the updater = magic :-)
Steve
thanks 1 user thanked stevespaw for this useful post.
richardgatarski on 4/1/2016(UTC)
TVIason
#24 Posted : Thursday, March 31, 2016 4:41:10 PM(UTC)
TVIason
Was thanked: 9 time(s) in 8 post(s)
Stevespaw,
I installed the client you gave us the link of. It was a bit overwhelming and somewhat chaotic layout, but I Will Look into it tomorrow.
Thank you!
Iason
kane
#25 Posted : Thursday, March 31, 2016 5:33:56 PM(UTC)
kane
richardgatarski wrote:
Kane Peterson
NewTek
Thanks Kane!
The 'NewTek Video Send' installer puts it files in 'C:\Windows\system32' on 32-bit systems or 'C:\Windows\SysWOW64' folder on 64-bit systems. After you run the AirSend Updater you will find the new Processing.AirSend.x86.dll in the same location and the previous file with 'OLD' added to its name.
Kane Peterson
NewTek
richardgatarski
#26 Posted : Friday, April 1, 2016 3:31:43 AM(UTC)
richardgatarski
Steve, that little line revealed the secret sauce. Unfortunately it was not in TVlason's otherwise excellent Youtube guide.
It turns out the name of the NewTek driver's installation kit is "NewTek Network Video Send.exe", and what it install is the AirSend stuff I did not have. In other words, I was fooled by a little bit of name confusion. Of course I then had to run the "NewTek NDI AirSend Updater.exe" which does what Kane said above (although without the updater reporting if it did anything or not).
So, in other words I got Casparcg working. Now I will look into why NewBlueFX's Titler Pro Live 2 does not show up as an NDI source for me, but that's another topic.
Thank you all for helping out!
ask
#27 Posted : Friday, April 1, 2016 4:10:46 AM(UTC)
ask
Richard, it looks like you have to have the Titler Pro Live 2 Ultimate edition to get the NDI output. I have downloaded both the standard version and the Advanced and both do not include NDI.
richardgatarski
#28 Posted : Friday, April 1, 2016 5:14:02 AM(UTC)
richardgatarski
Well, nahumf reported earlier that it worked not using the Ultimate (which is not released yet). I asked, nahumf for details, still no answer...
ask
#29 Posted : Friday, April 1, 2016 6:03:59 AM(UTC)
ask
Read here....https://www.newbluefx.com/support/help-files/titler-pro-live-2-help/standalone-specific-options
TVIason
#30 Posted : Saturday, April 2, 2016 5:22:10 AM(UTC)
TVIason
It works for me aswell in the trial mode.
Went to TitlerLive Standalone.exe>Device> NDI and worked
richardgatarski
#31 Posted : Saturday, April 2, 2016 5:58:24 AM(UTC)
richardgatarski
What do you mean by "device> NDI"? Is there a setting somewhere for choosing output device?
TVIason
#32 Posted : Saturday, April 2, 2016 6:02:02 AM(UTC)
TVIason
Yes there is, it's under settings
richardgatarski
#33 Posted : Saturday, April 2, 2016 6:33:33 AM(UTC)
richardgatarski
Strange, I don't have that option in the menu...
richardgatarski attached the following image(s):
TVIason
#34 Posted : Saturday, April 2, 2016 6:36:03 AM(UTC)
TVIason
Hmm, because I didn't now how the program could be started, I went to my Program Files folder and started the program from there. (C:\Program Files\NewBlueFX\TitlerLive\TitlerLiveStandalone
Could you try that for me?
richardgatarski
#35 Posted : Saturday, April 2, 2016 6:39:34 AM(UTC)
richardgatarski
Doesn't help. I'll just ask NewBlueFx's support. I'll be back when I know more.
Thanks.
Guest (10)
2 Pages<12
