Tagore
#1 Posted : Thursday, July 19, 2012 7:43:32 PM(UTC)
Tagore
Hi, with the recent addition of the virtual set to the soft , i bring the this question:
how do you generate the virtual sets? can any of the commercial virtual set in the market be used in vmix?
Best regards.
#2 Posted : Saturday, July 21, 2012 3:31:47 AM(UTC)
Was thanked: 4674 time(s) in 1609 post(s)
Have a look at the VirtualSets folder in your vMix installation directory.
You can copy one of the existing folders and modify the images create a custom virtual set that way.
Tagore
#3 Posted : Saturday, July 21, 2012 7:36:00 AM(UTC)
Tagore
ok so the quick answer is:
The virtual set need to be edited by hand ( not easy way for customers )
Cannot be used any of the commercial virtual sets ( cannot bring easy way to who already have working another solutions )
Rigth?
Best regards.
#4 Posted : Saturday, July 21, 2012 9:48:57 AM(UTC)
Most commercial virtual sets can be provided in png/jpeg format which can be manually built into a vMix template
by using the existing templates as an example.
Additional virtual sets will made available for vMix in the coming months and a virtual set builder is currently being considered.
Tagore
#5 Posted : Saturday, July 21, 2012 9:55:04 AM(UTC)
Tagore
Thx Martin, virtual set builder would be really usefull.
Best regards.
Similar Topics
Multiple angle from virtual set. (General Discussion)
by Aaron LPH 11/3/2020 12:36:13 PM(UTC)
Virtual Set. (3rd Party Software and Development)
by fdooman 7/16/2018 11:25:09 AM(UTC)
(VIDEO)Cropping Video with Lumakey,xaml and Virtual Set. (General Discussion)
by joe1378 6/23/2014 12:10:10 PM(UTC)
