Hi, with the recent addition of the virtual set to the soft , i bring the this question:
how do you generate the virtual sets? can any of the commercial virtual set in the market be used in vmix?
Best regards.
Joined: 1/13/2010(UTC) Posts: 5,375  Location: Gold Coast, Australia Was thanked: 4801 time(s) in 1648 post(s)
Have a look at the VirtualSets folder in your vMix installation directory. You can copy one of the existing folders and modify the images create a custom virtual set that way.
Martin vMix
ok so the quick answer is:
The virtual set need to be edited by hand ( not easy way for customers ) Cannot be used any of the commercial virtual sets ( cannot bring easy way to who already have working another solutions )
Rigth?
Best regards.
Most commercial virtual sets can be provided in png/jpeg format which can be manually built into a vMix template by using the existing templates as an example.
Additional virtual sets will made available for vMix in the coming months and a virtual set builder is currently being considered.
Thx Martin, virtual set builder would be really usefull.
Best regards.
