tomsimon
#1 Posted : Sunday, January 17, 2016 5:50:30 PM(UTC)
tomsimon
Hi guys,
I installed instant replays - all works fine. Just the problem ist if i start "play event" a replay the output and preview turns to black screen and there is no Outpu.
[img]http://www.directupload.net/file/d/4235/yrou6kgl_png[/img]
Would be very cool if you can help me to fixx this problem!
#2 Posted : Sunday, January 17, 2016 7:24:01 PM(UTC)
@ tomsimon
It may take some trouble shooting but for starters, what is "Detail Kamera" input and why is it black?
Is there any chance it is being 'Overlayed' on the "Replay A" Input by accident? (MultiView Overlay)
Or being the primary source Input for Replay?
tomsimon
#3 Posted : Monday, January 18, 2016 5:59:16 AM(UTC)
tomsimon
Detail cam is our second camera, i did not started her for this replay test.
In instant replay the only conifgured camera is the "totale"..
Could you say me which shortcuts you added for playing a replay?
Thanks!
#4 Posted : Monday, January 18, 2016 7:08:00 AM(UTC)
Was thanked: 4711 time(s) in 1615 post(s)
What sort of device/capture card is Totale?
The screenshot is showing that instant replay is not receiving any frames from the device so it may not be compatible with Instant Replay.
tomsimon
#5 Posted : Monday, January 18, 2016 8:39:04 AM(UTC)
tomsimon
Its a black magic mini recorcer (HDMI / SDI) we use HDMI
#6 Posted : Monday, January 18, 2016 10:49:17 AM(UTC)
Thanks,
Try creating a new blank replay session folder and try recording on that.
If that doesnt help, check inside the replay folder for log files after recording that should indicate what is happening.
tomsimon
#7 Posted : Wednesday, January 20, 2016 7:51:46 AM(UTC)
tomsimon
admin wrote:
Thanks,
That has worked, but this problem is every time. Is there any fix for that?
Very annoying for us!
#8 Posted : Wednesday, January 20, 2016 8:18:14 AM(UTC)
Check in the broken replay folder for the replay.xml and email that to us.
info@vmix.com
Also make sure files are not being deleted manually as this will mess up the replay.
It is best to use a brand new folder for each game.
