Instant Replay
Replays Output just black
Joined: 1/17/2016(UTC) Posts: 4 Location: Ulm, Germany
Hi guys, I installed instant replays - all works fine. Just the problem ist if i start "play event" a replay the output and preview turns to black screen and there is no Outpu. [img]http://www.directupload.net/file/d/4235/yrou6kgl_png[/img]  Would be very cool if you can help me to fixx this problem!
@ tomsimon
It may take some trouble shooting but for starters, what is "Detail Kamera" input and why is it black? Is there any chance it is being 'Overlayed' on the "Replay A" Input by accident? (MultiView Overlay) Or being the primary source Input for Replay?
Detail cam is our second camera, i did not started her for this replay test.
In instant replay the only conifgured camera is the "totale"..
Could you say me which shortcuts you added for playing a replay?
Thanks!
Joined: 1/13/2010(UTC) Posts: 5,375  Location: Gold Coast, Australia Was thanked: 4801 time(s) in 1648 post(s)
What sort of device/capture card is Totale?
The screenshot is showing that instant replay is not receiving any frames from the device so it may not be compatible with Instant Replay.
Martin vMix
Its a black magic mini recorcer (HDMI / SDI) we use HDMI
Thanks,
Try creating a new blank replay session folder and try recording on that. If that doesnt help, check inside the replay folder for log files after recording that should indicate what is happening.
admin wrote:Thanks,
Try creating a new blank replay session folder and try recording on that. If that doesnt help, check inside the replay folder for log files after recording that should indicate what is happening. That has worked, but this problem is every time. Is there any fix for that? Very annoying for us!
Check in the broken replay folder for the replay.xml and email that to us. info@vmix.comAlso make sure files are not being deleted manually as this will mess up the replay. It is best to use a brand new folder for each game.
Instant Replay
