ClementN
#1 Posted : Friday, July 13, 2012 12:05:37 PM(UTC)
ClementN
Romania
I am trying to fit 5 Intensity Pro cards on a Asus P8Z77-V DELUXE MB
(http://www.asus.com/Motherboards/Intel_Socket_1155/P8Z77V_DELUXE/)
Every time I add the 5th cam as Capture Module, the modules no 3 and 4 starts to flicker .
In fact, it seems they are alternate in showing the image like they are sharing the bandwidth on the MB (which is not the case according to the manual).
However, if I use on the the card as output card (so 4 input + 1 output) then everything is ok .
I suppose there is same bandwidth consumption no mater if there is input or output for a card.
Is that right?
I am using the latest version of vMix (v4. Test) with 1080ix1920 PAL.
What do you think?
melody
#2 Posted : Friday, July 13, 2012 12:26:19 PM(UTC)
Rank: Guest
Groups:
hi ClementN,
maybe you can take a look on this thread:
http://forums.vmix.com.a...t.aspx?g=posts&t=118
it maybe helps you...
regards,
melody
www.espiritosanto.cc
#3 Posted : Friday, July 13, 2012 1:28:44 PM(UTC)
Hi ClementN,
According to the motherboard notes:
*4: The PCIe x1_2 shares bandwidth with SATA6G_E12. SATA6G_E12 is enabled by default for system resource optimization.
The manual mentions the SATA6G_E12 as the Marvell SATA controller so disabling that in the BIOS might help.
ClementN
#4 Posted : Saturday, July 14, 2012 4:07:16 AM(UTC)
ClementN
Romania
Hello Melody,
Thanks. I saw that thread but is not exactly my case.
Here each card is working but NOT all 5 at once as input. Also, 4 input + 1 output is working perfectly.
Hello Martin,
I did that from the first place. This is why I suppose that according to the MB manual, all 5 cards are ok.
