5 Intensity Pro set-up (oppinion needed)
Joined: 5/7/2012(UTC) Posts: 185  Location: Bucharest Thanks: 48 times Was thanked: 13 time(s) in 11 post(s)
I am trying to fit 5 Intensity Pro cards on a Asus P8Z77-V DELUXE MB (http://www.asus.com/Motherboards/Intel_Socket_1155/P8Z77V_DELUXE/)
Every time I add the 5th cam as Capture Module, the modules no 3 and 4 starts to flicker . In fact, it seems they are alternate in showing the image like they are sharing the bandwidth on the MB (which is not the case according to the manual).
However, if I use on the the card as output card (so 4 input + 1 output) then everything is ok .
I suppose there is same bandwidth consumption no mater if there is input or output for a card.
Is that right?
I am using the latest version of vMix (v4. Test) with 1080ix1920 PAL.
What do you think?
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Hi ClementN,
According to the motherboard notes:
*4: The PCIe x1_2 shares bandwidth with SATA6G_E12. SATA6G_E12 is enabled by default for system resource optimization.
The manual mentions the SATA6G_E12 as the Marvell SATA controller so disabling that in the BIOS might help.
Martin vMix
Hello Melody,
Thanks. I saw that thread but is not exactly my case. Here each card is working but NOT all 5 at once as input. Also, 4 input + 1 output is working perfectly.
Hello Martin,
I did that from the first place. This is why I suppose that according to the MB manual, all 5 cards are ok.
