Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
Since the last update I've been experiencing some trouble with the display driver collapsing after the program has been running runs for some number of minutes. The details: - Windows 10 - AMD Hexacore CPU @ 3.4 GHz - AMD Radeon HD7400 GPU - Latest drivers When the trouble occurs the app loses access to the webcams, but is otherwise stable. Windows alerts that the display driver has collapsed and restarted. I close vMix, launch it anew and all is well...for a while.  I've noticed that it seems to happen when there's an MOV file used as a background animation. The file in question is a 200 MB PNG encoded animation. I'm going to convert that file to an MP4 and see if it continues to occur. Michael
I used VLC to convert the MOV to a highly compressed MP4. That's been playing in vMix for a couple of hours without incident.
On that basis, I gather that MOV files are now something of a problem. At least under Windows 10.
Michael
Not, the problem doesn't seem to be related to the MOV file as I thought. The fault just occurred in a version of the file the uses the MP4 background animation. The display driver collapsed and this is what I saw.  This time I found that I could reset the webcams and get the scene back without even restarting vMix. Both webcams (Logitech BCC950 & C920) are operating at 1280x720p30 MJPG. I'm running the very latest AMD Catalyst for Windows 10. Any advice?
Are there any vMix logs that I can access to see what was happening when the problem occurs?
