Problem capture 2nd screen from remote PC.
Hello. Simply setup - vmix16 on main PC and output to big screen. Desktop capture from notebook with karaoke software. Connection by short cable - no problem with quality and fps. When I start karaoke player (song text + background video) on 2nd screen, on vmix source window I see only song text, but no background video. Notebook - windows XP and ATI videocard.
Is it possible to see the video, or cause in overlay ATI videocard?
I fix this problem mix text from remote PC and background from vmix, not so good, but work.
Joined: 3/30/2014(UTC) Posts: 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
Hi mkobzar,
I don't know if this helps but I just tried to look into your problem, I have a Macbook Pro linked up to vMix via desktop capture, I don't have any karaoke software so I went onto youtube and played some videos through desktop capture into vMix and I have been running it for two hours now with no problems, all video and sound is in sync. I am using a second screen and all is working fine.
Is there any free karaoke software I could try to see if I get the same problem?
Thanks: 7 times Was thanked: 15 time(s) in 14 post(s)
Could this be a content protection issue? I know karaoke has alll kinds of ASCAP and BMI restrictions on its use to it stands to reason that some content may be protected by some sort of HDCP.
I think it's not type of protected software. Just player + text. Here is solution.  Big screen show only text+background from other input vmix. LCD over the right edge show text+karaoke video. It works! Thanks, VMIX!
