mkobzar
#1 Posted : Monday, November 2, 2015 11:37:02 PM(UTC)
mkobzar
Hello.
Simply setup - vmix16 on main PC and output to big screen.
Desktop capture from notebook with karaoke software. Connection by short cable - no problem with quality and fps.
When I start karaoke player (song text + background video) on 2nd screen, on vmix source window I see only song text, but no background video.
Notebook - windows XP and ATI videocard.
Is it possible to see the video, or cause in overlay ATI videocard?
I fix this problem mix text from remote PC and background from vmix, not so good, but work.
Len56
#2 Posted : Tuesday, November 3, 2015 9:15:59 PM(UTC)
Len56
Hi mkobzar,
I don't know if this helps but I just tried to look into your problem, I have a Macbook Pro linked up to vMix via desktop capture, I don't have any karaoke software so I went onto youtube and played some videos through desktop capture into vMix and I have been running it for two hours now with no problems, all video and sound is in sync. I am using a second screen and all is working fine.
Is there any free karaoke software I could try to see if I get the same problem?
jhebbel
#3 Posted : Wednesday, November 4, 2015 7:58:24 AM(UTC)
jhebbel
Could this be a content protection issue? I know karaoke has alll kinds of ASCAP and BMI restrictions on its use to it stands to reason that some content may be protected by some sort of HDCP.
mkobzar
#4 Posted : Wednesday, November 4, 2015 9:12:47 AM(UTC)
mkobzar
I think it's not type of protected software. Just player + text.
Here is solution.
Big screen show only text+background from other input vmix.
LCD over the right edge show text+karaoke video.
It works! Thanks, VMIX!
