fortsquarechurch
#1 Posted : Sunday, October 4, 2015 2:48:35 PM(UTC)
fortsquarechurch
Hello there,
My church is starting to use vMix to record Worship Services.
We want to use a VCR as a back up if there's a power outage or if the digital recording is no good.
Is it possible to connect a Honestech VidBox 5.0 VHS to DVD to record to VCR?
Thanks.
ask
#2 Posted : Sunday, October 4, 2015 4:37:41 PM(UTC)
ask
The VidBox is in only. You will need to come out HDMI than go through a HDMI to Component converter.
fortsquarechurch
#3 Posted : Sunday, October 4, 2015 4:42:16 PM(UTC)
fortsquarechurch
Okay, how do I hook it up and be able to use external?
Ittaidv
#4 Posted : Sunday, October 4, 2015 6:38:31 PM(UTC)
Ittaidv
The blackmagic intensity pro has an rca output, I used it already once, works great!
fortsquarechurch
#5 Posted : Sunday, October 4, 2015 7:00:07 PM(UTC)
fortsquarechurch
I found this...
Portta 100HC Mini HDMI to 3RCA Composite AV Converter for TV/PC/PS3/Blue-ray DVD1080P,White / Black
Will that work?
If I connect HDMI to PC and RCA to VHS Player?
#6 Posted : Sunday, October 4, 2015 8:36:21 PM(UTC)
@ fortsquarechurch
That looks like it should work, although I would not have high expectations on the 'quality'.
fortsquarechurch on 10/7/2015(UTC)
fortsquarechurch
#7 Posted : Sunday, October 4, 2015 8:39:29 PM(UTC)
fortsquarechurch
I just figured out a cheap way to do it.
Open Control Panel
Set up Extended Displays
Connect a TV via RCA to USB
Go on vMix and set up Multiple Displays
Set it to output full screen
Insert the tape into the VCR
Then record
fortsquarechurch
#8 Posted : Wednesday, October 7, 2015 12:22:55 PM(UTC)
fortsquarechurch
Thanks for you help guys
Similar Topics
Question on recording to VCR (General Discussion)
by fortsquarechurch 1/27/2017 9:20:57 AM(UTC)
