Hello there,
My church is starting to use vMix to record Worship Services.
We want to use a VCR as a back up if there's a power outage or if the digital recording is no good.
Is it possible to connect a Honestech VidBox 5.0 VHS to DVD to record to VCR?
Thanks.
The VidBox is in only. You will need to come out HDMI than go through a HDMI to Component converter.
Okay, how do I hook it up and be able to use external?
The blackmagic intensity pro has an rca output, I used it already once, works great!
I found this...
Portta 100HC Mini HDMI to 3RCA Composite AV Converter for TV/PC/PS3/Blue-ray DVD1080P,White / Black
Will that work?
If I connect HDMI to PC and RCA to VHS Player?
@ fortsquarechurch
That looks like it should work, although I would not have high expectations on the 'quality'.
I just figured out a cheap way to do it.
Open Control Panel Set up Extended Displays Connect a TV via RCA to USB Go on vMix and set up Multiple Displays Set it to output full screen Insert the tape into the VCR Then record
