andyreader
#1 Posted : 10 years ago
andyreader
I'm planning on getting a Decklink Mini Recorder capture card(http://www.amazon.com/Blackmagic-Design-DeckLink-Recorder-Capture/dp/B00CDIXCSO/ref=sr_1_1?ie=UTF8&qid=1437402240&sr=8-1&keywords=decklink+mini+recorder&pebp=1437402250667&perid=033ZQNYT540RKB2NMPPF) to possibly use in an IMAG situation. Can anybody tell me what is the latency they receive from this card? Whether it is noticeable or not. I read other posts saying that the Decklink cards are very good but wasn't sure whether this one is part of them or they are referring to the higher end ones.
Speegs
#2 Posted : 10 years ago
Speegs
I have the thunderbolt model and the latency was good. As far as I know the latency is good on all the capture products usually < 2 frames. The power of your computer would be more likely to cause a latency issue.
Ash
#3 Posted : 10 years ago
Ash
Was thanked: 11 time(s) in 8 post(s)
I also use the thunderbolt model and latency is very small.
richardgatarski
#4 Posted : 10 years ago
richardgatarski
Was thanked: 299 time(s) in 251 post(s)
In my experience there is, and will, always be a noticeable delay in IMAG situations when using s/w switchers (like vMix). Although I have not used this particular card.
One trick is to delay the mic audio to the PA to compensate a little bit. I would say the result is acceptable, although some audio engineers perhaps won't agree ;)
Maybe ovinas (another vMix user with good insight) has something to say on this matter.
Also, I have found that the IMAG output from vMix must be a Fullscreen output, using External implies additional delay.
ovinas
#5 Posted : 10 years ago
ovinas
They are quit good for the money you pay. I have two of them in one PC. The latency is a bit more compared to hardware switchers like Panasonic or Analog Way but here we are talking of 3000 Euros and more. But the latency problem mostly isn't a problem of one component. You have to watch your signal chain starting with the camera and ending with converters and even the projector or monitor. Each component will add some latency and if you have components that add only a little bit more latency than others it could be annoying. Adding delay to the audio is possible but there are "red lines" you have to find with the audio guys. Normally these red lines will end prior to compensate the visible latency ;-) So as Richard wrote, you will always have it and it's noticeable.
Similar Topics
BM decklink mini recorder freeze Randomly (Hardware Compatibility)
by Pberry 4 years ago
Decklink mini recorder 4k (Hardware Compatibility)
by Rodrigo Rey 6 years ago
Windows 10 1803 Update Breaks Inputs (XI400DE, XI100DUSB, Blackmagic Decklink Mini Recorder) (Hardware Compatibility)
by brandin 7 years ago
Decklink mini recorder (non 4k) (Hardware Compatibility)
by Epag 8 years ago
DeckLink Mini Recorder 4K latency? (Hardware Compatibility)
by jhebbel 8 years ago
DeckLink Mini Recorder 4K - for 1080 or 720 Broadcasts (Hardware Compatibility)
by SHMD 8 years ago
Decklink mini Recorder USB 3.0 (Hardware Compatibility)
by dmwanderley 8 years ago
Blackmagic Design DeckLink Mini Recorder & Stream (Hardware Compatibility)
by STADIORADIO 9 years ago
No Signal from Blackmagic Decklink Mini Recorder (Hardware Compatibility)
by mazac 10 years ago
BlackMagic Decklink Mini recorder, not working with a HDMI splitter. (Hardware Compatibility)
by Jackster 11 years ago
Blackmagic Design Decklink Mini Recorder (Hardware Compatibility)
by imagebotique 11 years ago
Support for DeckLink Series includes DeckLink Mini Recorder? (Hardware Compatibility)
by atpt 12 years ago
