bunayya01
#1 Posted : Friday, June 26, 2015 2:59:13 AM(UTC)
bunayya01
help plise when i turn on stream.. the mesage is..
ffmpeg.exe -threads 4 -f dshow -i video="vMix Virtual
Capture":audio="Microphone (Fast Track)" -f flv "rtmp://
ec2-50-112-32-198.us-west-2.compute.amazonaws.com:1935/live/fgbc-live"
-vcodec libx264 -s vga -r 24 -vb 500 -acodec libvo_aacenc -ar 22050 -ab 128k
ffmpeg version N-40126-ga4b58fd Copyright (c) 2000-2012 the FFmpeg
developers
built on Apr 26 2012 03:29:50 with gcc 4.6.3
configuration: --enable-gpl --enable-version3 --disable-w32threads
--enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r
--enable-libass
--enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb
--enable
-libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut
--enable-libope
njpeg --enable-librtmp --enable-libschroedinger --enable-libspeex
--enable-libth
eora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc
--enable-
libvorbis --enable-libvpx --enable-libx264 --enable-libxavs
--enable-libxvid --e
nable-zlib
libavutil 51. 47.100 / 51. 47.100
libavcodec 54. 15.100 / 54. 15.100
libavformat 54. 3.100 / 54. 3.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 72.100 / 2. 72.100
libswscale 2. 1.100 / 2. 1.100
libswresample 0. 11.100 / 0. 11.100
libpostproc 52. 0.100 / 52. 0.100
[dshow @ 0229f340] Stream #1: not enough frames to estimate rate; consider
incre
asing probesize
Input #0, dshow, from 'video=vMix Virtual Capture:audio=Microphone (Fast
Track)'
Duration: N/A, start: 4742.286000, bitrate: N/A
Stream #0:0: Video: rawvideo (UYVY / 0x59565955), uyvy422, 640x480,
29.97 fp
s, 29.97 tbr, 10000k tbn, 29.97 tbc
Stream #0:1: Audio: pcm_s16le, 44100 Hz, 2 channels, s16, 1411 kb/s
[dshow @ 0229f340] real-time buffer 101% full! frame dropped!
Last message repeated 9 times
HandShake: client signature does not match!
[buffer @ 01d331a0] w:640 h:480 pixfmt:uyvy422 tb:1/1000000 sar:0/1
sws_param:fl
ags=2
[buffersink @ 01d3e1c0] auto-inserting filter 'auto-inserted scale 0'
between th
e filter 'src' and the filter 'out'
[scale @ 01d3e4a0] w:640 h:480 fmt:uyvy422 sar:0/1 -> w:640 h:480
fmt:yuv420p sa
r:0/1 flags:0x4
Guessed Channel Layout for Input Stream #0.1 : stereo
Output #0, flv, to 'rtmp://
5/live/fgbc-live':
Metadata:
encoder : Lavf54.3.100
Stream #0:0: Video: flv1 ([2][0][0][0] / 0x0002), yuv420p, 640x480,
q=2-31,
200 kb/s, 1k tbn, 29.97 tbc
Stream #0:1: Audio: mp3 ([2][0][0][0] / 0x0002), 44100 Hz, stereo, s16
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo -> flv)
Stream #0:1 -> #0:1 (pcm_s16le -> libmp3lame)
Press [q] to stop, [?] for help
Input stream #0:1 frame changed from rate:44100 fmt:s16 ch:2 chl:0x0 to
rate:441
00 fmt:s16 ch:2 chl:0x3
Last message repeated 126 times
frame= 28 fps=6.1 q=2.0 size= 226kB time=00:00:01.40
bitrate=1320.2kbits/s
Last message repeated 138 times
frame= 44 fps=4.6 q=2.3 size= 476kB time=00:00:05.90 bitrate=
661.4kbits/s
Last message repeated 64 times
[dshow @ 0229f340] real-time buffer 80% full! frame dropped!
frame= 63 fps=5.2 q=6.5 size= 607kB time=00:00:10.89 bitrate=
456.4kbits/s
frame= 75 fps=5.1 q=14.1 size= 737kB time=00:00:13.39 bitrate=
450.7kbits/
Last message repeated 38 times
frame= 88 fps=5.4 q=18.1 size= 793kB time=00:00:15.89 bitrate=
408.8kbits/
Last message repeated 20 times
frame= 95 fps=5.5 q=15.4 size= 845kB time=00:00:17.38 bitrate=
398.0kbits/
Last message repeated 16 times
frame= 104 fps=5.7 q=17.8 size= 891kB time=00:00:18.38 bitrate=
396.9kbits/
Last message repeated 14 times
frame= 117 fps=6.1 q=23.5 size= 934kB time=00:00:19.40 bitrate=
394.3kbits/
Last message repeated 12 times
frame= 131 fps=6.5 q=30.0 size= 971kB time=00:00:20.40 bitrate=
389.8kbits/
Last message repeated 11 times
frame= 148 fps=7.0 q=31.0 size= 1003kB time=00:00:21.39 bitrate=
384.1kbits/
Last message repeated 23 times
frame= 166 fps=7.4 q=31.0 size= 1056kB time=00:00:22.39 bitrate=
386.3kbits/
Last message repeated 10 times
frame= 172 fps=7.5 q=31.0 size= 1087kB time=00:00:23.39 bitrate=
380.5kbits/
Last message repeated 7 times
frame= 191 fps=8.0 q=31.0 size= 1118kB time=00:00:24.38 bitrate=
375.6kbits/
frame= 196 fps=8.0 q=31.0 Lsize= 1151kB time=00:00:25.01 bitrate=
376.9kbits
/s
video:1033kB audio:110kB global headers:0kB muxing overhead 0.664374%
how to fix this??
thanks before..
Speegs
#2 Posted : Friday, June 26, 2015 6:30:59 AM(UTC)
Speegs
I would try FMLE and see if you get the same result, not long term just to get additional insight into the problem. FMLE is a free download, worth installing as it's been stable for much longer than FFMPEG via Vmix (FFMPEG is great, but FMLE is old reliable).
Someone might know more than me, but I have only seen this message when accidentally setting the bitrate higher than my upstream link could possibly do. Yes I added an extra 0 to the bitrate and took me a while to figure that out. If you could do a speedtest at the time to a server in a similar zone and check the bandwidth available is about 30% more than the bitrate you are using should be ok.
I hope that points you in the right direction.
Ernest Król
#3 Posted : Saturday, June 27, 2015 2:31:50 AM(UTC)
Ernest Król
increase -rtbufsize value ieg.
Code:
ffmpeg.exe -f dshow -rtbufsize 2G -i video="vMix Video"...
in this example rtbufsize has value of 2Gigs
bunayya01
#4 Posted : Tuesday, June 30, 2015 11:27:25 PM(UTC)
bunayya01
Code:
may you tell me from begin to the end step by step to increase the rtbuffer plise??
thanks before.. :)
#5 Posted : Wednesday, July 1, 2015 12:21:12 AM(UTC)
Was thanked: 4711 time(s) in 1615 post(s)
The ffmpeg log file looks quite strange.
It appears a very old version of vMix is being used.
Please install the latest version from our web site that has built in streaming support.
bunayya01
#6 Posted : Wednesday, July 1, 2015 2:18:26 AM(UTC)
bunayya01
thanks for attention, i use vmix ver.14 when i update and use vmix ver.15 same problem back, i can't stream with 1000kbps vidio bitrate real time buffer become full again..
thanks before.. :)
#7 Posted : Wednesday, July 1, 2015 2:23:37 AM(UTC)
This log file is from 2012, so it does not appear to be related to vMix 14 or 15, but before streaming was
enabled back in vMix 8 or earlier.
In any case, if you cant stream at 1Mbps run a speedtest on speedtest.net to make sure your internet connection is fast enough.
bunayya01
#8 Posted : Thursday, July 2, 2015 9:03:45 PM(UTC)
bunayya01
but I have installed the latest vmix , and uninstall the old version..
my connection is 3mbps for upload..
and remains that real time streaming buffer full ..
I using vmix hd version .. any solution?
#9 Posted : Thursday, July 2, 2015 9:06:37 PM(UTC)
Could you send a screenshot showing the message?
Thanks,
Speegs
#10 Posted : Friday, July 3, 2015 12:54:28 AM(UTC)
Speegs
I know this sounds strange, but to help diagnostics maybe just open up FMLE (turn on any capture device as a source) and see what it says going to the same server. That will not fix your problem of course, but if it works without error will prove the problem is with FFMPEG or how VMix is launching FFMPEG.
Sometimes doing something similar to the result you want to achieve, but not the same with another way directs you to cause of the issue or at least rules out many other factors are causing a problem.
If you have already tried, ignore me completely :)
