FRAME DROPED, REAL TIME BUFFER FULL [HELP]
help plise when i turn on stream.. the mesage is..
ffmpeg.exe -threads 4 -f dshow -i video="vMix Virtual Capture":audio="Microphone (Fast Track)" -f flv "rtmp:// ec2-50-112-32-198.us-west-2.compute.amazonaws.com:1935/live/fgbc-live" -vcodec libx264 -s vga -r 24 -vb 500 -acodec libvo_aacenc -ar 22050 -ab 128k
ffmpeg version N-40126-ga4b58fd Copyright (c) 2000-2012 the FFmpeg developers built on Apr 26 2012 03:29:50 with gcc 4.6.3 configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass --enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable -libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libope njpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libth eora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable- libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --e nable-zlib libavutil 51. 47.100 / 51. 47.100 libavcodec 54. 15.100 / 54. 15.100 libavformat 54. 3.100 / 54. 3.100 libavdevice 53. 4.100 / 53. 4.100 libavfilter 2. 72.100 / 2. 72.100 libswscale 2. 1.100 / 2. 1.100 libswresample 0. 11.100 / 0. 11.100 libpostproc 52. 0.100 / 52. 0.100 [dshow @ 0229f340] Stream #1: not enough frames to estimate rate; consider incre asing probesize Input #0, dshow, from 'video=vMix Virtual Capture:audio=Microphone (Fast Track)' : Duration: N/A, start: 4742.286000, bitrate: N/A Stream #0:0: Video: rawvideo (UYVY / 0x59565955), uyvy422, 640x480, 29.97 fp s, 29.97 tbr, 10000k tbn, 29.97 tbc Stream #0:1: Audio: pcm_s16le, 44100 Hz, 2 channels, s16, 1411 kb/s [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 9 times HandShake: client signature does not match! [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 9 times [buffer @ 01d331a0] w:640 h:480 pixfmt:uyvy422 tb:1/1000000 sar:0/1 sws_param:fl ags=2 [buffersink @ 01d3e1c0] auto-inserting filter 'auto-inserted scale 0' between th e filter 'src' and the filter 'out' [scale @ 01d3e4a0] w:640 h:480 fmt:uyvy422 sar:0/1 -> w:640 h:480 fmt:yuv420p sa r:0/1 flags:0x4 Guessed Channel Layout for Input Stream #0.1 : stereo Output #0, flv, to 'rtmp:// ec2-50-112-32-198.us-west-2.compute.amazonaws.com:193 5/live/fgbc-live': Metadata: encoder : Lavf54.3.100 Stream #0:0: Video: flv1 ([2][0][0][0] / 0x0002), yuv420p, 640x480, q=2-31, 200 kb/s, 1k tbn, 29.97 tbc Stream #0:1: Audio: mp3 ([2][0][0][0] / 0x0002), 44100 Hz, stereo, s16 Stream mapping: Stream #0:0 -> #0:0 (rawvideo -> flv) Stream #0:1 -> #0:1 (pcm_s16le -> libmp3lame) Press [q] to stop, [?] for help [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Input stream #0:1 frame changed from rate:44100 fmt:s16 ch:2 chl:0x0 to rate:441 00 fmt:s16 ch:2 chl:0x3 [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 126 times frame= 28 fps=6.1 q=2.0 size= 226kB time=00:00:01.40 bitrate=1320.2kbits/s real-time buffer 101% full! frame dropped! [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 138 times frame= 44 fps=4.6 q=2.3 size= 476kB time=00:00:05.90 bitrate= 661.4kbits/s real-time buffer 101% full! frame dropped! [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 64 times [dshow @ 0229f340] real-time buffer 80% full! frame dropped! Last message repeated 64 times frame= 63 fps=5.2 q=6.5 size= 607kB time=00:00:10.89 bitrate= 456.4kbits/s real-time buffer 101% full! frame dropped! [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 64 times frame= 75 fps=5.1 q=14.1 size= 737kB time=00:00:13.39 bitrate= 450.7kbits/ real-time buffer 101% full! frame dropped! [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 38 times frame= 88 fps=5.4 q=18.1 size= 793kB time=00:00:15.89 bitrate= 408.8kbits/ real-time buffer 101% full! frame dropped! [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 20 times frame= 95 fps=5.5 q=15.4 size= 845kB time=00:00:17.38 bitrate= 398.0kbits/ real-time buffer 101% full! frame dropped! [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 16 times frame= 104 fps=5.7 q=17.8 size= 891kB time=00:00:18.38 bitrate= 396.9kbits/ real-time buffer 101% full! frame dropped! [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 14 times frame= 117 fps=6.1 q=23.5 size= 934kB time=00:00:19.40 bitrate= 394.3kbits/ real-time buffer 80% full! frame dropped! [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 12 times frame= 131 fps=6.5 q=30.0 size= 971kB time=00:00:20.40 bitrate= 389.8kbits/ real-time buffer 80% full! frame dropped! [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 11 times frame= 148 fps=7.0 q=31.0 size= 1003kB time=00:00:21.39 bitrate= 384.1kbits/ real-time buffer 80% full! frame dropped! [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 23 times frame= 166 fps=7.4 q=31.0 size= 1056kB time=00:00:22.39 bitrate= 386.3kbits/ real-time buffer 80% full! frame dropped! [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 10 times frame= 172 fps=7.5 q=31.0 size= 1087kB time=00:00:23.39 bitrate= 380.5kbits/ real-time buffer 80% full! frame dropped! [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 7 times frame= 191 fps=8.0 q=31.0 size= 1118kB time=00:00:24.38 bitrate= 375.6kbits/ real-time buffer 80% full! frame dropped! [dshow @ 0229f340] real-time buffer 101% full! frame dropped! Last message repeated 11 times frame= 196 fps=8.0 q=31.0 Lsize= 1151kB time=00:00:25.01 bitrate= 376.9kbits /s video:1033kB audio:110kB global headers:0kB muxing overhead 0.664374% [dshow @ 0229f340] real-time buffer 101% full! frame dropped!
how to fix this?? thanks before..
Joined: 8/3/2013(UTC) Views messages in topic : 405 Location: Gold Coast, Australia
I would try FMLE and see if you get the same result, not long term just to get additional insight into the problem. FMLE is a free download, worth installing as it's been stable for much longer than FFMPEG via Vmix (FFMPEG is great, but FMLE is old reliable).
Someone might know more than me, but I have only seen this message when accidentally setting the bitrate higher than my upstream link could possibly do. Yes I added an extra 0 to the bitrate and took me a while to figure that out. If you could do a speedtest at the time to a server in a similar zone and check the bandwidth available is about 30% more than the bitrate you are using should be ok.
I hope that points you in the right direction.
Joined: 11/12/2012(UTC) Posts: 58  Location: Tarnów, Poland Thanks: 22 times Was thanked: 4 time(s) in 4 post(s)
increase -rtbufsize value ieg. Code:ffmpeg.exe -f dshow -rtbufsize 2G -i video="vMix Video"...
in this example rtbufsize has value of 2Gigs
Originally Posted by: Ernest Kró  increase -rtbufsize value ieg. Code:ffmpeg.exe -f dshow -rtbufsize 2G -i video="vMix Video"...
in this example rtbufsize has value of 2Gigs may you tell me from begin to the end step by step to increase the rtbuffer plise?? thanks before.. :)
Joined: 1/13/2010(UTC) Posts: 5,320  Location: Gold Coast, Australia Was thanked: 4721 time(s) in 1617 post(s)
The ffmpeg log file looks quite strange. It appears a very old version of vMix is being used.
Please install the latest version from our web site that has built in streaming support.
admin wrote:The ffmpeg log file looks quite strange. It appears a very old version of vMix is being used.
Please install the latest version from our web site that has built in streaming support. thanks for attention, i use vmix ver.14 when i update and use vmix ver.15 same problem back, i can't stream with 1000kbps vidio bitrate real time buffer become full again.. thanks before.. :)
This log file is from 2012, so it does not appear to be related to vMix 14 or 15, but before streaming was enabled back in vMix 8 or earlier.
In any case, if you cant stream at 1Mbps run a speedtest on speedtest.net to make sure your internet connection is fast enough.
admin wrote:This log file is from 2012, so it does not appear to be related to vMix 14 or 15, but before streaming was enabled back in vMix 8 or earlier.
but I have installed the latest vmix , and uninstall the old version.. my connection is 3mbps for upload.. and remains that real time streaming buffer full .. I using vmix hd version .. any solution?
Could you send a screenshot showing the message?
Thanks,
Martin vMix
bunayya01 wrote: but I have installed the latest vmix , and uninstall the old version..
I know this sounds strange, but to help diagnostics maybe just open up FMLE (turn on any capture device as a source) and see what it says going to the same server. That will not fix your problem of course, but if it works without error will prove the problem is with FFMPEG or how VMix is launching FFMPEG. Sometimes doing something similar to the result you want to achieve, but not the same with another way directs you to cause of the issue or at least rules out many other factors are causing a problem. If you have already tried, ignore me completely :)
