Joined: 6/16/2015(UTC) Posts: 193   Location: Milton Keynes, UK Thanks: 10 times Was thanked: 53 time(s) in 27 post(s)
Hi
I am building a system that requires 7 x live SDI camera inputs, and 1 x SDI program output. Whilst the output will be SD 576i, the cameras can be set to 576i, 720p, 1080p. As I will be using virtual sets, with zoom, it is obviously a good idea that my talent is shot in HD to allow a greater definition when zoomed.
I am planing on using an i7 / 4 core / 8 thread 3Ghz CPU / 12GB RAM / Windows 8.1 / Nividia GFX 980 Graphics / with 2 x DeckLink Quad Capture boards, using 7 of the DeckLink channels as input, and the eighth as an output.
Can anybody tell me can I use 2 x Decklink Quad PCIe boards, and can I use 7 channels as input, and one as output?, and should this PC be able to deal with the workload?
Thanks in Advance
Keith
kgoodyer wrote:Hi
Thanks in Advance
Keith
Yes you can.. see full specifications of supported hardware and some custom built system configurations here to help you more: 1. http://www.vmixhd.com/supported-hardware.aspx2. http://www.vmixhd.com/go/3. http://www.vmixhd.com/go...O_BasePlus_SellSheet.pdfBest of luck
Thanks: 17 times Was thanked: 5 time(s) in 4 post(s)
But does vMix support Corvid88? It is not listed under supported hardware.
According to AJA, all of their new cards are compatible with vmix. There is a post on the forum somewhere from AJA which confirms this. I would direct any questions about the card to their sales team.
Joined: 8/5/2013(UTC) Posts: 281  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
