kgoodyer
#1 Posted : Tuesday, June 16, 2015 12:55:26 PM(UTC)
kgoodyer
Was thanked: 53 time(s) in 27 post(s)
Hi
I am building a system that requires 7 x live SDI camera inputs, and 1 x SDI program output. Whilst the output will be SD 576i, the cameras can be set to 576i, 720p, 1080p. As I will be using virtual sets, with zoom, it is obviously a good idea that my talent is shot in HD to allow a greater definition when zoomed.
I am planing on using an i7 / 4 core / 8 thread 3Ghz CPU / 12GB RAM / Windows 8.1 / Nividia GFX 980 Graphics / with 2 x DeckLink Quad Capture boards, using 7 of the DeckLink channels as input, and the eighth as an output.
Can anybody tell me can I use 2 x Decklink Quad PCIe boards, and can I use 7 channels as input, and one as output?, and should this PC be able to deal with the workload?
Thanks in Advance
Keith
Damn2Good4U
#2 Posted : Tuesday, June 16, 2015 3:46:17 PM(UTC)
Damn2Good4U
kgoodyer wrote:
Hi
Thanks in Advance
Keith
Yes you can.. see full specifications of supported hardware and some custom built system configurations here to help you more:
1. http://www.vmixhd.com/supported-hardware.aspx
2. http://www.vmixhd.com/go/
3. http://www.vmixhd.com/go...O_BasePlus_SellSheet.pdf
Best of luck
#3 Posted : Tuesday, June 16, 2015 6:03:00 PM(UTC)
@ kgoodyer
Another option is the AJA Corvid 88
https://www.aja.com/en/p...ucts/developer/corvid-88
Kinda pricy but it's all on one card...
thomas
#4 Posted : Wednesday, June 17, 2015 11:43:17 AM(UTC)
thomas
But does vMix support Corvid88? It is not listed under supported hardware.
IceStream wrote:
@ kgoodyer
ask
#5 Posted : Wednesday, June 17, 2015 6:41:47 PM(UTC)
ask
According to AJA, all of their new cards are compatible with vmix. There is a post on the forum somewhere from AJA which confirms this. I would direct any questions about the card to their sales team.
r@wisla
#6 Posted : Thursday, June 18, 2015 4:04:42 AM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
http://www.streamingmedi...ed-Technology_37441.aspx
Similar Topics
RTX 5080/5090 vs. A5000 for new system build? (Systems)
by Stefan-H 2/5/2025 12:57:18 AM(UTC)
Double checking new system build (Systems)
by sunkast 12/14/2023 2:45:46 AM(UTC)
New System Build for vMix (Hardware Compatibility)
by vinull 3/27/2013 12:59:32 PM(UTC)
