3rd Party Software and Development
remote audio control - with ipad or via mackie control surface
Was thanked: 6 time(s) in 3 post(s)
is anyone working on a remote control of the audio mixer pc software or tablet ?
I can see how to adjust via the api the volume of channels and audio inputs and I also have on my ipad a DAW controller that can remote control a audio desk or Digital Audio Workstation software mixer.
I guess it just needs a way to translate the DAW MACKIE commands over MIDI to vmix api calls.
I know the "just" is a lot of work but a lot less than building a complete mixer app.
any call/interest ?
I have been using and built a 5 SDI input 1 SDI output rack mount PC that runs vmix HD since January - its mostly used as a special input to our hardware vision mixer but it also goes out and streams live events when we need to do a cut down system.
Best
Alex.
silverstream.tv
Joined: 4/25/2014(UTC) Posts: 41  Location: Norway Thanks: 2 times Was thanked: 18 time(s) in 10 post(s)
Hi!
If you are interrested in paying, i can make a MIDI to vMix audio controller for you, you can see my other work at shop.njastad.com where we have programmed several MIDI panels, including motorized ones
Sondre Njåstad Developer @ shop.njastad.com
Joined: 2/27/2013(UTC) Posts: 312   Thanks: 8 times Was thanked: 78 time(s) in 43 post(s)
alexbyrd wrote:is anyone working on a remote control of the audio mixer pc software or tablet ?
any call/interest ?
Best
Alex.
silverstream.tv
Hey Alex! We will be integrating Audio Control into our vMix Control Software called vDesk soon! It will have full audio control and will resemble a channel strip of an audio mixer. Stay tuned! -Seth The Cloud Media Group
