alexbyrd
#1 Posted : Sunday, May 3, 2015 8:13:57 PM(UTC)
alexbyrd
Was thanked: 9 time(s) in 4 post(s)
is anyone working on a remote control of the audio mixer pc software or tablet ?
I can see how to adjust via the api the volume of channels and audio inputs and I also have on my ipad a DAW controller that can remote control a audio desk or Digital Audio Workstation software mixer.
I guess it just needs a way to translate the DAW MACKIE commands over MIDI to vmix api calls.
I know the "just" is a lot of work but a lot less than building a complete mixer app.
any call/interest ?
I have been using and built a 5 SDI input 1 SDI output rack mount PC that runs vmix HD since January - its mostly used as a special input to our hardware vision mixer but it also goes out and streams live events when we need to do a cut down system.
Best
Alex.
silverstream.tv
Sondrey
#2 Posted : Monday, May 4, 2015 5:43:27 PM(UTC)
Sondrey
Was thanked: 18 time(s) in 10 post(s)
Hi!
If you are interrested in paying, i can make a MIDI to vMix audio controller for you, you can see my other work at shop.njastad.com where we have programmed several MIDI panels, including motorized ones
Sondre Njåstad
Developer @ shop.njastad.com
thecloudmediagroup
#3 Posted : Wednesday, May 6, 2015 1:09:21 AM(UTC)
thecloudmediagroup
Was thanked: 78 time(s) in 43 post(s)
any call/interest ?
Best
Alex.
silverstream.tv
Hey Alex!
We will be integrating Audio Control into our vMix Control Software called vDesk soon! It will have full audio control and will resemble a channel strip of an audio mixer. Stay tuned!
-Seth
The Cloud Media Group
