Desktop Capture Not Working
I have vmix basic hd installed on my pc running windows 7 and desktop capture on my macbook pro with iOS 10.10.3. Vmix is giving me the error "A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond". My mcp firewall is not activated. I have redownloaded and installed desktop capture. I have Blackmagic intensity extreme and have un-installed that as well. Any suggestions?
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ johne
What version of vMix are you running? Was this working before?
Ice, Thanks for your response. Its vMix version 15.0.0.74 . The mcp is new so its the first time I've used desktop capture with it. I reset my wireless router and it is working now. I'm surprised since wifi seemed to be working, but glad it's running.
