kolmekahdeksan
#1 Posted : Saturday, May 4, 2013 7:19:03 PM(UTC)
kolmekahdeksan
Trying to stream stuff from VLC media player to vMix via RTSP. Video works like an animal but I can't get any audio coming through. I have tried multiple different settings (including MPEG 4 Audio ( AAC )) with VLC. Always the same result: no sound, no errors. And audio works fine when I stream it from VLC to VLC using RTSP.
Any help? Any suggestions? Anyone got this working?
Thanks in advance.
Btw. Checking out the trial version and whoa, #9 rocks! This is really getting good. Add multichannel ASIO IN/OUT-support and I'm completly 100% sold.
#2 Posted : Sunday, May 5, 2013 8:43:23 PM(UTC)
Was thanked: 4729 time(s) in 1621 post(s)
Here is the settings I have tested with using VLC:
Encapsulation: MP4/MOV
Video codec: H264
Audio codec: MPEG 4 Audio ( AAC ) BitRate: 128 kb/s Channels: 2 Sample Rate: 44100
Remember to untick "keep original audio track", otherwise VLC won't actually encode the audio if it is in a different format.
What version of VLC are you using and what is the source you are streaming?
android111123
#3 Posted : Thursday, January 29, 2015 5:44:12 PM(UTC)
android111123
Same problem here, and no solution :(
I use VLC 2.0.0 to stream H.264 and AAC audio.
I stream only audio, is it problem?
I tried many times your suggested settings but don't work.
Please help!
android111123 attached the following image(s):
NeObr
#4 Posted : Thursday, April 16, 2015 11:35:10 PM(UTC)
NeObr
admin any soluction for this case, i try many setups and many versions of VLC, no luck
