Trying to stream stuff from VLC media player to vMix via RTSP. Video works like an animal but I can't get any audio coming through. I have tried multiple different settings (including MPEG 4 Audio ( AAC )) with VLC. Always the same result: no sound, no errors. And audio works fine when I stream it from VLC to VLC using RTSP.
Any help? Any suggestions? Anyone got this working?
Thanks in advance.
Btw. Checking out the trial version and whoa, #9 rocks! This is really getting good. Add multichannel ASIO IN/OUT-support and I'm completly 100% sold.
Joined: 1/13/2010(UTC) Posts: 5,338  Location: Gold Coast, Australia Was thanked: 4741 time(s) in 1627 post(s)
Here is the settings I have tested with using VLC:
Encapsulation: MP4/MOV Video codec: H264 Audio codec: MPEG 4 Audio ( AAC ) BitRate: 128 kb/s Channels: 2 Sample Rate: 44100
Remember to untick "keep original audio track", otherwise VLC won't actually encode the audio if it is in a different format.
What version of VLC are you using and what is the source you are streaming?
Martin vMix
Same problem here, and no solution :( I use VLC 2.0.0 to stream H.264 and AAC audio. I stream only audio, is it problem? I tried many times your suggested settings but don't work. Please help! android111123 attached the following image(s):  rtsp1.png (28kb) downloaded 1 time(s). rtsp2.png (17kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
Joined: 4/16/2015(UTC) Posts: 18  Location: São Bernardo do Campo - SP - Brasil Thanks: 17 times Was thanked: 1 time(s) in 1 post(s)
admin any soluction for this case, i try many setups and many versions of VLC, no luck
