AWTW
#1 Posted : Sunday, September 7, 2014 6:36:18 PM(UTC)
AWTW
We are trying to use a Panasonic DVD player as an input in VMix via HDMI cable into an Intensity Pro. We only get a black screen. We have turned off all "auto" settings on the DVD player and have tried several different configurations in VMix regarding the video format, frame rate, etc. We can successfully add a DVD input from the computer DVD player, but not the external DVD player.
Any suggestions?
r@wisla
#2 Posted : Monday, September 8, 2014 3:31:33 AM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
HDCP?
http://en.wikipedia.org/...gital_Content_Protection
If You have component output from your dvd player - try connecting it that way.
LG
#3 Posted : Monday, September 8, 2014 5:15:08 AM(UTC)
LG
just put the dvb in your pc's dvd player?
you can use it as a "input" in vmix
wy a need to a external one? ( no time to swap the discs? ) 2e dvd in your pc ?
tdurhamjr
#4 Posted : Wednesday, April 15, 2015 1:55:17 PM(UTC)
tdurhamjr
Was thanked: 25 time(s) in 21 post(s)
I am now trying to add a DVD as an input into vMix. I tried this on my laptop and on my desktop and both gave me an error message. See the attached message. The DVD I have in for testing is a DVD Movie "Lord of the Rings". Not that it matters but just letting you know that is the DVD. It is DVD and not bluray. Can anyone give me any insight on what I need to do in order to add the DVD as an input. I am actually setting up my vMix to handle media presentation (not streaming) for a kids group. I will be mixing a DVD presentation, some Youtube videos, PowerPoint presentation, and maybe some other things. I am good with everything except the DVD input.
Thanks for any help!
Tim
tdurhamjr attached the following image(s):
DVD Error Message.png (76kb) downloaded 0 time(s).
tdurhamjr
#5 Posted : Wednesday, April 15, 2015 2:07:34 PM(UTC)
tdurhamjr
I should note that the DVD itself plays fine. It is just when I try to use the Add Input > DVD function in vMix that I get the error in vMix. My laptop is running 15.74 64bit and the PC from which the screenshot came is running 15.73 64bit.
ovinas
#6 Posted : Wednesday, April 15, 2015 2:23:22 PM(UTC)
ovinas
Media Center installed?
thanks 1 user thanked ovinas for this useful post.
tdurhamjr on 4/15/2015(UTC)
tdurhamjr
#7 Posted : Wednesday, April 15, 2015 3:18:49 PM(UTC)
tdurhamjr
Nope. Will do that now :) Did not know that was required. Thanks!!
ovinas
#8 Posted : Wednesday, April 15, 2015 3:35:06 PM(UTC)
ovinas
I think it's required for Windows 8 because of the missing MPEG-2 support without Media Center. I thought it was only required for recording but who knows... Just tested playing a DVD in vMix and it's working fine on my system with Windows 8.1 with Media Canter.
tdurhamjr
#9 Posted : Wednesday, April 15, 2015 9:56:57 PM(UTC)
tdurhamjr
You are AWESOME!! That took care of it. Thanks for the help. Maybe Martin will add a note in the help file to let other folks not familiar with that little tidbit know it is required :)
Tim
tdurhamjr
#10 Posted : Wednesday, April 15, 2015 10:19:51 PM(UTC)
tdurhamjr
Updating original post instead of adding another one. I had to install this:
http://www.ac3filter.net/wiki/Download_AC3Filter
And now sound is there. You have to set the audio decoder to AC3. Hopefully this will help others who run into the same problem.
RichShumaker
#11 Posted : Wednesday, April 6, 2016 8:09:19 PM(UTC)
RichShumaker
Was thanked: 28 time(s) in 23 post(s)
I am running into this error.
I have not installed Windows Media Center as this system already has quite a few Video applications and I am concerned about issues.
So the question is with Windows 10 is this issue moot as Windows Media Center does not exist in the new OS.
I am on Win 8.1 right now.
I do have a DVD player installed and the DVD does play on the system.
I did install the Audio driver except that did not clear up the 'MPEG-2 Decoder' issue that WMC resolves.
Any suggestions on what Codec or other software I might need instead of WMC?
Thanks everyone.
Rich Shumaker
Bandit62
#12 Posted : Wednesday, April 6, 2016 8:52:48 PM(UTC)
Rank: Guest
Groups: Guests
I had similar issues with DVDs both with vMix and another program....solved that by putting the DVD in the Drive, copy the TS files, and made an AVI file with my editor, and never had a problem since....when I am asked to play DVDs in anything I am doing, I simply convert to .avi, or quicktime files........
mjgraves
#13 Posted : Friday, April 8, 2016 4:09:44 PM(UTC)
mjgraves
You're far better of ripping the DVD to media files that vMix can handle from disk.
Guest (9)
