We are trying to use a Panasonic DVD player as an input in VMix via HDMI cable into an Intensity Pro. We only get a black screen. We have turned off all "auto" settings on the DVD player and have tried several different configurations in VMix regarding the video format, frame rate, etc. We can successfully add a DVD input from the computer DVD player, but not the external DVD player.
Any suggestions?
Joined: 8/5/2013(UTC) Posts: 281  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
just put the dvb in your pc's dvd player? you can use it as a "input" in vmix wy a need to a external one? ( no time to swap the discs? ) 2e dvd in your pc ?
Joined: 9/8/2014(UTC) Posts: 244 Location: Southaven MS
Thanks: 12 times Was thanked: 26 time(s) in 21 post(s)
I am now trying to add a DVD as an input into vMix. I tried this on my laptop and on my desktop and both gave me an error message. See the attached message. The DVD I have in for testing is a DVD Movie "Lord of the Rings". Not that it matters but just letting you know that is the DVD. It is DVD and not bluray. Can anyone give me any insight on what I need to do in order to add the DVD as an input. I am actually setting up my vMix to handle media presentation (not streaming) for a kids group. I will be mixing a DVD presentation, some Youtube videos, PowerPoint presentation, and maybe some other things. I am good with everything except the DVD input. Thanks for any help! Tim tdurhamjr attached the following image(s):  DVD Error Message.png (76kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
I should note that the DVD itself plays fine. It is just when I try to use the Add Input > DVD function in vMix that I get the error in vMix. My laptop is running 15.74 64bit and the PC from which the screenshot came is running 15.73 64bit.
 1 user thanked ovinas for this useful post.
ovinas wrote:Media Center installed? Nope. Will do that now :) Did not know that was required. Thanks!!
I think it's required for Windows 8 because of the missing MPEG-2 support without Media Center. I thought it was only required for recording but who knows... Just tested playing a DVD in vMix and it's working fine on my system with Windows 8.1 with Media Canter.
ovinas wrote:I think it's required for Windows 8 because of the missing MPEG-2 support without Media Center. I thought it was only required for recording but who knows... Just tested playing a DVD in vMix and it's working fine on my system with Windows 8.1 with Media Canter. You are AWESOME!! That took care of it. Thanks for the help. Maybe Martin will add a note in the help file to let other folks not familiar with that little tidbit know it is required :) Tim
Updating original post instead of adding another one. I had to install this: http://www.ac3filter.net/wiki/Download_AC3FilterAnd now sound is there. You have to set the audio decoder to AC3. Hopefully this will help others who run into the same problem.
Joined: 4/4/2016(UTC) Posts: 235  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
I am running into this error. I have not installed Windows Media Center as this system already has quite a few Video applications and I am concerned about issues. So the question is with Windows 10 is this issue moot as Windows Media Center does not exist in the new OS.
I am on Win 8.1 right now. I do have a DVD player installed and the DVD does play on the system.
I did install the Audio driver except that did not clear up the 'MPEG-2 Decoder' issue that WMC resolves.
Any suggestions on what Codec or other software I might need instead of WMC?
Thanks everyone.
Rich Shumaker
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
I had similar issues with DVDs both with vMix and another program....solved that by putting the DVD in the Drive, copy the TS files, and made an AVI file with my editor, and never had a problem since....when I am asked to play DVDs in anything I am doing, I simply convert to .avi, or quicktime files........
You're far better of ripping the DVD to media files that vMix can handle from disk.
