1920x1080 is vertically compressing my image on recording
Joined: 10/7/2014(UTC) Posts: 7 Location: san francisco
14.0.0.101 x64, win 7 sp1, i7 2660 I add input "HDR HC1 1920x1080 NTSC 29.97p bit rate 75 (use hardware encoder checked) " - the video/audio shows up fine (ignoring the audio delay). It looks great on screen. However, when I record it, the video is compressed vertically. It distorts the image and adds black bars on the top and bottom of the screen. In the image below - the top is the file that vMix produces. The bottom is that same file with the vertical dimension expanded 135% (making it normal) (and color corrected a bit) test. This normal image is what shows on the screen in vMix - but the recorded file is compressed. here is a 3 second test file from my camers (a darker room) - just so you can study the file to understand what the vertical compression is. http://rationalspirituality.com/test.mp4How can I fix this? Thanks!
Joined: 9/8/2014(UTC) Posts: 244 Location: Southaven MS
Thanks: 12 times Was thanked: 25 time(s) in 21 post(s)
You need to change the aspect ratio of the source. Click the "settings" icon in lower right corner of input window. See attached image. tdurhamjr attached the following image(s):  Aspect-Ratio.jpg (140kb) downloaded 3 time(s).You cannot view/download attachments. Try to login or register.
 1 user thanked tdurhamjr for this useful post.
that was it! thank you. I had missed your response but fixed it today. YES!
