asexymind
#1 Posted : Tuesday, November 11, 2014 1:09:11 PM(UTC)
asexymind
14.0.0.101 x64, win 7 sp1, i7 2660
I add input "HDR HC1 1920x1080 NTSC 29.97p bit rate 75 (use hardware encoder checked) " - the video/audio shows up fine (ignoring the audio delay). It looks great on screen.
However, when I record it, the video is compressed vertically. It distorts the image and adds black bars on the top and bottom of the screen.
In the image below - the top is the file that vMix produces. The bottom is that same file with the vertical dimension expanded 135% (making it normal) (and color corrected a bit) test. This normal image is what shows on the screen in vMix - but the recorded file is compressed.
here is a 3 second test file from my camers (a darker room) - just so you can study the file to understand what the vertical compression is. http://rationalspirituality.com/test.mp4
How can I fix this? Thanks!
tdurhamjr
#2 Posted : Tuesday, November 11, 2014 11:02:17 PM(UTC)
tdurhamjr
Was thanked: 26 time(s) in 21 post(s)
You need to change the aspect ratio of the source. Click the "settings" icon in lower right corner of input window. See attached image.
tdurhamjr attached the following image(s):
thanks 1 user thanked tdurhamjr for this useful post.
asexymind on 3/23/2015(UTC)
asexymind
#3 Posted : Monday, March 23, 2015 3:47:39 PM(UTC)
asexymind
that was it! thank you. I had missed your response but fixed it today. YES!
